Where the Plug at?
Old 12-08-2013, 10:04 PM
73f250cummins's Avatar
73f250cummins
73f250cummins is offline
Where the Plug at?
I cannot seem to find it on my 2006. I know where it was at on my 7.3 it was by the left front tow hook. Its cold and I don't want to keep starting it without it being plugged in much longer.
Old 12-08-2013, 10:10 PM
Piolet's Avatar
Piolet
Piolet is offline
All our trucks come with the block heater installed. I don't think they all came with the power cord. If yours did then it comes out of the engine on the passenger side at the starter and block drain plug. Then it routes along the frame rail up to the front bumper.
If you don't have one they can be bought from Ford, online or from an International dealer. I replaced mine and I don't have the info to hand right now. It was readily available locally from International and not too expensive if I recall.
Do a search on here and find the part #.
Old 12-08-2013, 10:15 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
It should only take a second to see if it there or not. I think my cord has an orange boot where it goes into the element, but it is definitely visible looking up from underneath.
PN - 6E7Z-6B018-AA
Old 12-08-2013, 10:17 PM
73f250cummins
Alright thanks guys, ill crawl under it tomorrow and take a look.
Old 12-08-2013, 11:05 PM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
I found mine between the tow hook and fog lamp with damn near zero play. the head can just be pulled enough so the prongs stick out. It had a cap on the prongs too, thats what I held on to plug it in the one time just to see if it worked.
Good luck
Clayton
Old 12-08-2013, 11:18 PM
73f250cummins
Ok I'll look at that also lupuseven. Thanks for you help guys best forum I've been on ever.
Old 12-08-2013, 11:29 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Josh
Old 12-08-2013, 11:39 PM
73f250cummins
Thansk Bullitt390 pics make it very helpful
Old 12-08-2013, 11:43 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Mine didn't come with one, I ended up buying it later. I think I paid $36 back in 2006.
Old 12-08-2013, 11:46 PM
73f250cummins
Hmm that's interesting, yeah I will know for sure after tomorrow wether it has one or not.
Old 12-08-2013, 11:50 PM
the_auto_tech's Avatar
the_auto_tech
the_auto_tech is offline
Mine has one, but for some reason it's got the 3 pin flat connector instead of the normal 110 connector. I've never seen a vehicle with the one I have. Thinking I may just need to buy the cord.
Old 12-08-2013, 11:54 PM
Bullitt390's Avatar
Bullitt390
The cord is 2 pieces. In my second pic that flat connector usually pins into the hole just above the frame sticker.
I removed that push pin so the cord could hang out of the grille opeing more.
Josh
Old 12-09-2013, 12:20 AM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
I think it was in 05 when Ford quit installing the cord as standard equipment. I think they were only standard in extreme cold areas. My 05 didn't have one when purchased new. Had to buy a cord from Ford and install. Then found out that I could have bought it from IH and saved some money...
Old 12-09-2013, 10:52 AM
73f250cummins
How much did it run you threw ford?
Old 12-09-2013, 03:31 PM
davidkstyler's Avatar
davidkstyler
davidkstyler is offline
Got one on eBay a year or so ago.
Did a quick search today and found http://www.ebay.com/itm/Ford-7-3-6-0-6-4-6-7-L-Powerstroke-Diesel-Block-Heater-Cord-/200997812462?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecc6738ee&vxp=mtr for $26+$6 shipping
RECON 1880
12-19-2011 08:49 PM
jearll
1999 to 2016 Super Duty
02-08-2011 12:24 PM
jstarr
10-08-2010 04:50 PM
jfrobinson2000
11-16-2007 09:51 PM
2012 SD Snowbuster
01-24-2007 09:45 AM
Quick Reply: Where the Plug at?
