He's pissed that not one agrees with him. They gave him part #s. It's his loss. Ford replaced 3 EGR coolers & flushed mine by 40,000+ miles, 92,000+ now & I just replaced the 5th coolant filter & you wouldn't believe the amount of sand in the filter when I cut it open.
Find a brass fitting and splice it in instead of replacing the hose.
Try this part number to replace it: 3C3Z-18472-BB
I believe this was an honest attempt to answer your question. Depends on if your tuck has the heater control valve I think. The hose would be a different part number depending.
Btw, my bpd oil hose routes under the pass side battery tray, then through the radiator header beneath the a/c lines. Not even close to my dieselsite coolant filter.
If your bpd hose is ABOVE the pass battery tray (mine was initially) the hose will wear a hole from rubbing on the battery tray edge.
Hmmm,it's also Mark's fault half us installed the filter in the first place. Now he lists a part# that causes bad karma on a dedicated FTE member,all because Mark failed to find that one garage who knows the straight skinny on coolant filters. Not
