Heater Hose Part Number
I broke one of my heater hoses lifting the cab.
Can anyone Identify this one?
Broke right at the special connector so I will need the hose and the quick connect clamp assembly.
The parts shops have a hose listed but I'm not sure if it is correct and would come with the connector
I just need the short piece up to the hose clamp on that vacum thing.
I had to order the whole thing. I was actually looking for just the little hose piece with the special connector on the side that attaches to the heater core on the firewall. The rest of my hose and my control valve are fine.
I find it odd, that you would disconnect the heater hose at the plastic coupling to the heater core. Normally when I do cab-off repairs, I disconnect that hose where it joins the metal L shaped tube just below the alternator, and leave the hose attached to the heater core and swung out of the way, before I raise the cab.
The old hose end was a PITA to remove. I'm guessing most people would get to them from the glove box or use the special tools to remove them. They sure do go on easy thing =D
Charlie's Ranger
03-22-2018 11:13 AM
