3G issue
Old Dec 4, 2013 | 12:27 PM
84espy's Avatar
84espy
3G issue
I did the 3G swap. Love the concept, but I have been having a squealing belt issue, ever since. The belt is lined up. I went to an AX42 belt in the hopes of filling up the pulley, but the squeal still exists. My first PNP alternator went by the wayside. I bought a rebuilt one and the squeal is there. Any tips before I decide to re-invent the wheel?
Old Dec 4, 2013 | 03:09 PM
jsutton's Avatar
jsutton
What brand belt did you get? I had to go with a more expensive good quality belt "gatorback" to avoid squealing.
Old Dec 4, 2013 | 05:13 PM
HIO Silver's Avatar
HIO Silver
I suggest scuffing/cleaning the pulley grooves with a coarse Scotchbrite pad and re-tensioning the belt.
The belt should ride in the groove rather than on top of it. Ideally, it should sit no higher than the pulley's outer circumference.
Old Dec 4, 2013 | 07:52 PM
wyckedcombo17's Avatar
wyckedcombo17
x2, is the squeal at the alternator or the crank? lightly wire wheel wherever its slipping
Old Dec 4, 2013 | 08:15 PM
V10man's Avatar
V10man
An old shade tree trick is to rub the belt with a bar of soap. I remember doing that to my belts back in the day and it worked.
The single belt is really good for about 120A or so. If you're pulling a lot of amps that could be an issue.
Old Dec 4, 2013 | 11:12 PM
buttwheat's Avatar
buttwheat
Check your belt alignment. If you put in to big of an alternator a single belt wont cut the mustard there is a reason they don't come with a single belt pulley on them.
Old Dec 5, 2013 | 06:36 AM
psychlopath's Avatar
psychlopath
He already mentioned the belt alignment is OK and the alternator wont squeal from load unless there is a pretty significant load on it; like charging a very low battery or running something that creates a serious draw.
Just go serpentine and be done with it.
Old Dec 5, 2013 | 07:57 AM
84espy's Avatar
84espy
What is needed for this? Also, what models had the 2 pulley alternators?
Old Dec 5, 2013 | 08:52 AM
buttwheat's Avatar
buttwheat
Oops sorry I missed that
84espy how did you check the alignment? String, straight edge, visual or laser alignment?
I agree with the dual belts or serpentine belt
Old Dec 5, 2013 | 10:03 AM
psychlopath
What engine do you have? I've seen some walkthroughs for a 460. I think you'd need a new water pump to go with the pulleys.
You can buy two grove pulleys online. I had one, but I never got around to having a crank pulley with two of the same size grooves on it. Rjm Injection gsm them, I think, but I got mine from Napa.
Old Dec 5, 2013 | 03:03 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
He already mentioned the belt alignment is OK .
Doesn't mean the OP is right...
It only takes a degree of misalignment to get squeal.
Josh
Old Dec 5, 2013 | 06:41 PM
psychlopath
We can only work with what we're given. He says it's aligned.
84espy: Did you already have a solution in mind when you mentioned reinventing the wheel?
Old Dec 5, 2013 | 09:40 PM
84espy's Avatar
84espy
I was thinking of putting in a separate idler pulley that would be machined to fit the backside of the belt. The alternator would then be fixed with the idler picking up the slack with the belt wrapping the full 180 around the pulley.
Also, if I go double pulley, wouldn't I have to change the water pump pulley?
Old Dec 5, 2013 | 09:54 PM
psychlopath
I didnt change mine. I never RAN the second belt I put on, but I did fit it up. That was about the time I noticed that my crank pulley wouldnt work with it.
This was on a 400, though. I'm not sure on anything else.
Some pages online have measurements, so you could figure it out before buying, or maybe even mock something up.
Old Dec 9, 2013 | 04:13 PM
84espy's Avatar
84espy
So I went to PNP for some more ideas on this pulley business. I found a double pulley alternator in a Bronco. The crank pulley was there and it looked like both pulley grooves were the same size. The other thing I noticed was that the alternator pulley was not wrapped around the water pump. Mine is. Is mine configured wrong? Is there enough turn from the power steering pump/crank to operate the water pump with no ill affects? I also found an idler pulley that I'm going to tinker with.
Lots of bullnose there. Not too many dents or bumps, though.
