Alarm install help
Old Dec 3, 2013 | 02:00 PM
jemelems's Avatar
jemelems
Alarm install help
I have a 1999 Econoline camper, and I'm trying to install a Viper alarm.
Instruction manual here:
Download Viper_3105V_Installation_Guide.pdf for free - EbookBrowsee.net - Ebook Search & Free Ebook Downloads
Wiring Diagram here:
1997-2003*Ford*Econoline*Vehicle Wiring Chart and Diagram
I've followed the wiring diagram, I cut off the relay off of the Ground When Armed wire because I read somewhere I didn't need it for a basic install with no add ons, the violet to the black wire off of the door pin, and I spliced the door trigger input and the instant trigger input wires together to the green wire coming off the door open/close pin (can anyone verify this is correct? These need to be spliced to a wire that goes to ground when door is opened). I've ran into a couple hiccups with the lock/unlock function. The alarm function works, but the doors will not lock/unlock. I checked the driver side kick panel, and I found two pink wires, I don't remember the color stripe, but one had 12vDC when I hit the lock button, and one had 12vDC when I hit the unlock button, so I spliced the Viper green wire to the one that had 12v when lock was pressed, and the Viper blue wire when unlock was pressed. Did I splice to the wrong wires, should the Viper green and blue wires be swapped?
Old Dec 4, 2013 | 07:26 AM
JWA's Avatar
JWA
Does your van have the Remote Keyless Entry feature?
Old Dec 4, 2013 | 08:05 PM
gene daniels's Avatar
gene daniels
Stopped by for the door hinges.
I don't know what you're doing there but yes the wires are on a 2008 red/pink..red/yellow...or red green.
splice in negative door open to one and negative door lock to the other or possible your system uses only one for both as a sequence.
why the other wires were cut or immobilized ? Prob not.
You are not altering the stock system only adding a separate ground wire relay control.
the wire controls are prob experimentally switchable as the brain unit is foolproofed.
Old Dec 7, 2013 | 07:39 PM
jemelems's Avatar
jemelems
It did not come with a remote, but since the wiring diagram webiste says the pink wires are only if van was remote entry equipped, I would assume the van has it.
I didn't understand a single sentence.
Old Dec 7, 2013 | 07:40 PM
jemelems's Avatar
jemelems
My van is not a 2008, it's a 1999.
Old Dec 8, 2013 | 07:12 AM
JWA's Avatar
JWA
I'm not familiar with the Viper system although page #37 of your install guide looks strikingly similar to my Omega Crime Guard 350i system.
The PDL's require a full 12 VDC to lock/unlock and without a proper two-relay circuit installed for that purpose the Viper "brain" cannot supply that voltage/current. Here's a schematic for my system, should apply to your's as well:
Not sure where you're physically locating your alarm "brain" but mine is just behind the driver side B Pillar---easy access to the lock/unlock wires running to the rear doors. All switches and solenoids are in parallel anyway so tapping into the correct wires is simple at that location.
If you have Club Wagon trim you'll need to find another location for the unit and tying into chassis wiring. Personally I'd connect into the wiring right side chassis wiring harness near the inertia fuel shut off switch---right side outer kick panel.
Hope this isn't too confusing, hoping more its helpful!
Old Dec 9, 2013 | 03:18 PM
jemelems's Avatar
jemelems
Well the only two doors I need to lock and unlock are the driver's side and passenger side.. This van is the camper model, and I'm only alarming and wiring keyless entry to the cab portion of the camper. My Viper's brain is located under the steering column, behind the cover that snaps in right under the steering wheel. What I don't understand is why the wiring diagram says tie to a pink/yellow and a pink/light green, which I did, and it won't lock/unlock the cab... And I have no clue where the fuel shut off switch would be.
Old Dec 12, 2013 | 06:13 AM
JWA's Avatar
JWA
For the correct wire colors you need to access a Ford schematic for your year and chassis. While Viper is a good company they might not be fully aware of every color wire for every model.
The inertia fuel shut off is located in the passenger side foot well, opposite the doghouse or on the outside wall. Its just above the snap-in trim panel. Right below that switch is a mass of wires that's easily accessible.
Lee Lichterman
Electrical Systems/Wiring
Sep 13, 2022 04:41 AM
Mr.ford
1997 - 2003 F150
Sep 9, 2012 05:59 PM
shenders99
Oct 28, 2006 01:15 PM
Pastmaster
Feb 6, 2006 01:32 PM
cgalvin31
Feb 20, 2005 12:37 AM
