low turbo boost code
Old Dec 3, 2013 | 07:56 AM
Ray Hamel13's Avatar
Ray Hamel13
2006 F250 6.0 Diesel with 88K miles.
I was towing my 14,000 lb. 5th wheel at about 65mph. Stopped at a rest area and when I restarted, the engine shaped light came on. The code showed "Low Turbo Boost". I drove about 900 miles until I could cancel out the code. The engine ran great all this time with good boost, acceleration and power so I am baffled.
I have not towed since the code was canceled (just city driving) but the light has not returned...YET. Is there anything I need to be concerned about or have looked at OR does this sometimes happen??????
Thanks for any enlightening words you all can give.
Old Dec 3, 2013 | 10:36 AM
BLADE35's Avatar
BLADE35
Post the Exact CODE/DTC
Might have a Dirty MAP or EBP sensor or Tube
You can Clean those with Carb Cleaner
Other then that you need a ScanGaugeII or something to read LIVE DATA
Worse case you have to pull and clean turbo or VGT is going out but that's not too common so Start with the Sensors cleaning and get a gauge
Old Dec 4, 2013 | 08:05 AM
Ray Hamel13
Thanks for the reply.
Not too familiar with these items so will do some research and take one at a time. The truck mileage is now in the 80's so it is time to start checking into those things to make sure emissions have not hampered their operation.
Thanks for your help.
Rifleman3
May 8, 2018 10:45 PM
j4henry
Mar 19, 2012 06:16 PM
steelhead2
Sep 21, 2009 04:13 PM
Tore
Jun 26, 2008 04:26 PM
hazard
May 18, 2008 03:56 PM
