Low boost numbers and p132b code
Old Mar 19, 2012 | 08:25 AM
j4henry's Avatar
j4henry
Ive got a 2003 6.0 and it runs ok but I keep getting this code. I also notice the sometimes when you punch it to pullout in traffic it hesitates. the boost never goes above 19psi when I pull my tt it sometimes goes to 21psi. So far I have cleaned the turbo, new egr valve, cleaned map sensor and hose, checked for leakes and found none. Only thing I haven't done is have the intake hot tanked to remove carbon. Could an intake with heavy buildup of carbon cause this condition or is my turbo going out slowly?
Old Mar 19, 2012 | 08:58 AM
Unrealo4's Avatar
Unrealo4
Ive heard that this code means sticking vanes and or replace the turbo. Thatsaid you cleaned the turbo did you see any pitting, rust or worn unision ring? My truck will on occasion pop this code as well. I used to only see 21 psi tops on boost. Over the last little bit ive been getting up to 24psi. But i still have this code randomly with no side effects. I know i have a small exhaust leak before the turbo and i belive that is where my problem is. But i have been waiting for another major repair like upgradeing to arps or a oil cooler rebuild to tackle this.
Old Mar 19, 2012 | 09:50 AM
BLADE35's Avatar
BLADE35
Right P132b have fun with this one lots of possibilities
code p132B
https://www.ford-trucks.com/forums/1...132b-code.html
try that for starters^^^^^^^^^^^^^
Old Mar 19, 2012 | 05:23 PM
critterf1's Avatar
critterf1
code p132B
You got that right. You can chase your *** for days on this code.
Old Mar 19, 2012 | 06:16 PM
j4henry's Avatar
j4henry
So basically frigg it til it all goes south
Ray Hamel13
Dec 4, 2013 08:05 AM
cmdevildog16
Jan 28, 2012 09:30 PM
whtrdng
Jul 8, 2009 07:44 AM
BulldogBob
Nov 12, 2008 10:00 PM
fhartell
Aug 2, 2007 08:04 PM
