Turbo Kits ... Again
Old Dec 1, 2013 | 05:26 PM
1972RedNeck's Avatar
1972RedNeck
I have done a lot of reading lately on Banks vs. ATS vs. Hypermax turbo kits.
One thing I have not been able to find though, is which kit leaves the most room to work on glowplugs.
As far as servicing the motor goes (GP's, injectors, return lines, GP controller), which kit is best?
Old Dec 1, 2013 | 05:32 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv no idea how the others are (i think the oem ats is tight though and sits right up over the left side real hard for some reason) but here is my banks setup;
intercooled 2nd gen (latest) sidewinder banks.0% issue working around engine.for some things some pipe might need to come out but that's easy enough and hasn't happened yet.
Old Dec 1, 2013 | 06:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
My ATS 088 is easy to work around, as is the old banks. Looking at F250s pic i would say there is plenty of room around the sidewinder. Furthermore it is speculated the the sidewinder kit may be the easiest to build off of as far as using an aftermarket turbo.
Old Dec 1, 2013 | 07:13 PM
vfelix702's Avatar
vfelix702
f250..... you isulated your whole firewall? to cut down on in cab noise?
Old Dec 1, 2013 | 07:20 PM
hairyboxnoogle
I think he was more after heat deflection, but no doubt the noise insulation was a bonus.
Old Dec 1, 2013 | 07:37 PM
FORDF250HDXLT
yeah i did.it was mostly for the additional sound deadening.some of these 9th gens came with one from the factory.a big thick black one.this truck didn't have it.so i installed two layers of this;
EZ Cool Automotive Insulation heat barrier and noise reduction for cars, trucks, classic cars, street rods and much more
running my new to me f450 home,i noticed it was more quite though than my truck.i noticed it has the thick oem sound deadening.does that show up in my pic.........
yeah.see it here:
(this one was originally white as you can see.)
^pretty hard to beat working around an n/a.
but,what little extra effort there is,is trumped all to heck with all that extra nut lol!
i added a layer there over the hood liner because that was starting to brake apart in the middle.that'll hold it.
Old Dec 1, 2013 | 07:48 PM
kla94's Avatar
kla94
I'll try to get a good pic of my 093 setup tomorrow. It's factory and looks to be tighter than the sidewinder.
Old Dec 1, 2013 | 08:54 PM
Chevy_Eater's Avatar
Chevy_Eater
Here's some good pictures of the Hypermax system courtesy Tom (85-6.9L). Interesting item on the Hypermax is it allows you to keep the factory air cleaner:
https://www.ford-trucks.com/forums/1...l#post13068714
Old Dec 1, 2013 | 09:17 PM
RacinNdrummin's Avatar
RacinNdrummin
I wouldn't judge a Turbo Kit based off of how easy it is to change things like GP's, that's a once in tens of thousands of miles sort of deal. However, I would say the that the ATS 093 kit is probably the worst, only because of the #7 cylinder. However, the extra 15 minutes that takes is hardly worth buying an inferior turbo.
Old Dec 2, 2013 | 07:10 PM
1972RedNeck
I can see were you are coming from.
Who has the best turbo kit? (from a horsepower/mileage standpoint)
Old Dec 2, 2013 | 07:20 PM
kla94's Avatar
kla94
Didn't get a chance to get the pic. Had to take my lady to the doctor. My camera takes lousy pics in the dark. I'll get them though.
Old Dec 2, 2013 | 08:48 PM
Red454sedgwick's Avatar
Red454sedgwick
I got a factory turbo and a banks and they are about the same, from the working on point of view. the banks is a little better because you don't have to take the air box off every time to work on it.
Old Dec 2, 2013 | 08:53 PM
hairyboxnoogle
R&D of course
Old Dec 2, 2013 | 09:19 PM
1972RedNeck
Originally Posted by hairyboxnoogle
R&D of course
If only I had the time....
Old Dec 2, 2013 | 09:21 PM
Red454sedgwick
Well then Id take another 2nd gen banks over my factory
