Temperature/Heater issue
Old Dec 1, 2013 | 05:09 PM
  #46
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not at a dealer, they've been obsolete for 30 years.
Green Sales and Miller show them in stock.
What about the Gates 33129?
Old Dec 1, 2013 | 05:21 PM
  #47
Brnfree's Avatar
Brnfree
With the engine cold, take the radiator cap off. Then start the engine. Go around and look down the radiator. If you can see water flowing in the radiator right after a cold start, your thermostat is stuck open.
Good answer Franklin, fast, simple, effective, and free.
Since you're already gonna do the t-stat on your new to you, used truck, how about giving it a flush, new hoses, and a fresh charge of distilled water* and a-freeze.
*Was told distilled water minimizes possible mineral build up in the cooling system.
Old Dec 1, 2013 | 05:24 PM
  #48
FordPUMan's Avatar
FordPUMan
Yes I was definitely thinking about doing the whole flush thing while I was at it. Thanks.
Old Dec 1, 2013 | 10:56 PM
  #49
ctubutis's Avatar
ctubutis
Originally Posted by FordPUMan
On the sticker
on the radiator support it says engine family 5.8M/6.6NA.
Which is saying: Engine Family: 351M or 400
Someplace near there it should list the displacement, e.g. 351 cid.
Old Jan 31, 2014 | 08:49 PM
  #50
FordPUMan's Avatar
FordPUMan
I know its been a while, but between work,Christmas,ice storm,having
a bad cold,too cold outside,etc,etc, I finally found time to get back on
this. After I drained and flushed it, I took the heater hoses off at the engine and tried to run water through the heater.
Nothing flowed at first but after running water both ways it finally flushed out with a very good water flow both
ways. Next I took off the thermostat housing and no thermostat. I was able to get a Stant from the local parts store. After I got everything put back together and buckled up,filled with coolant/water I started to check for leaks
and after giving it time to heat up I tried the heater and defroster. Both worked as good as new. And the temp gauge was registering. A great big
THANKS to everyone for their help,ideas and suggestions and also for
pointing out the difference in the thermostats!
Old Jan 31, 2014 | 10:19 PM
  #51
ctubutis's Avatar
ctubutis
Originally Posted by ArdWrknTrk
Google search brings me to a page of Gary's epic thread where he says....
Ha!!!!!!!!!!!!! I had to LOL at that (even though it's a month old). Reps sent.
BTW Jim I *moved* that thread with your cut-up heater core (and changed the title a bit) to the FAQs subforum, shouldn't be so hard to find anymore. Just use the "Search This Forum" thing on the top-RH navbar thing).
N.B. I really need to go clean up & fix up some of the broken stuff in those subforums...
https://www.ford-trucks.com/forums/1...r-problem.html
Old Feb 1, 2014 | 03:22 AM
  #52
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
FordPUman,
Thanks for following up, letting us know what you found and how you resolved it.
Chris, thanks for all the work you do to edit and organize these forums!
And the rep's of course. I'd hit you back if I could....
cardana24
1997 - 2003 F150
18
Mar 9, 2018 05:38 PM
A star
Aerostar
Mar 17, 2008 11:41 AM
Leykis101
20
Feb 22, 2006 09:37 AM
blue ranger
1983 - 2012 Ranger & B-Series
Jan 30, 2005 11:31 PM
dbc2004
Jun 24, 2004 06:14 PM
