Aerostar Ford Aerostar
Heater not heating
Old Mar 15, 2008 | 02:58 PM
A star's Avatar
A star
Heater not heating
I have a 94 areostar with 3.0 engine. The heater will only get a little warm ever after the engine has heated up to normal. I recently changed the thermostat and gasket because i noticed a small leak around the theromostat housing. I thought this would make the heater work better. The engine operating temperture improved to normal but the heater simply does not warm the van's insides, even with the heater and fan turned to high. This weekend I drove on a 700 mile trip. On the way back i had to add coolent because the engine temperure showed a little high. It took about a gallon. Any suggeations would be appreciated.
Old Mar 15, 2008 | 03:07 PM
Pablo-UA's Avatar
Pablo-UA
I used to flush my heater core twice....
Old Mar 15, 2008 | 06:50 PM
Baggins's Avatar
Baggins
I have been dealing with this for a couple of years with my 93.
I completely flushed out the block this winter, and that helped for awhile, but I don't think I got everything out so I'm doing it again this spring.
The core seems to get easily obstructed with the "gunk" that seems to grow in old blocks over time.
Old Mar 15, 2008 | 08:13 PM
96_4wdr's Avatar
96_4wdr
pays to flush heater cores both direction with water and air, not over 30 psi
water flow passages are much smaller than those in radiator
later models of Aeros have a vacuum valve in front heater core hose near firewall, these fail or plug
all rear heater aeros have a rear valve located under the floor near the heater that fails or plugs
check that the blend door closes comely and forces all fan air thru the heater core
with engine hot, the heater core should be too hot to hold hand to
Old Mar 15, 2008 | 08:21 PM
99f350sd's Avatar
99f350sd
Took about a gallon? Gosh either its using the stuff or there was air in the system.. Keep an eye on it. You need to check the blend door to make sure its moving in both directions.. Also it wouldn't hurt to remove the both heater hoses and flush the core with a garden hose. Go easy you don't want it to see too much pressure. House pressure can be 60 psi.. if the core is clogged the pressure will build up fast.
Dick
Old Mar 15, 2008 | 08:37 PM
copper_90680's Avatar
copper_90680
Put in a new radiator cap. You must be losing coolant to the overflow reservoir.
Old Mar 17, 2008 | 08:02 AM
DOUG5G's Avatar
DOUG5G
Any tips on how to get air out of the system?
Thanks
Doug
Old Mar 17, 2008 | 11:41 AM
Pablo-UA's Avatar
Pablo-UA
Floor a gas. Works!
