Heater hose
Old Jan 30, 2005 | 05:19 PM
blue ranger's Avatar
blue ranger
Angry Heater hose
I am in the process of trying to figure out the route of the heater hoses on my truck.It,s a 90 ranger with a 2.3 engine. My question is does it matter which side of the heater core they hook up too because i am having heat issues. I just changed the thermastat and the heater core was changed a couple of months ago. I think my issues could be a bad heater core.
Old Jan 30, 2005 | 05:37 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The heater will work no matter how the two houses are connected. Since you're having heat issues, and if the new thermostat doesn't cure it, check for proper operation of the blend door.
Old Jan 30, 2005 | 05:44 PM
blue ranger
I checked the blend door and it,s opening and closing when you move the selector from hot to cold. Does my model have any kind of heater control valve.
Old Jan 30, 2005 | 06:49 PM
CowboyBilly9Mile
If it did you would see it since one of your heater hoses would be in line with, and connected, to it. I'm not 100% sure, but I don't think they used them back than.
Old Jan 30, 2005 | 08:17 PM
Ken00's Avatar
Ken00
They would look like a vacuum motor in one of your heater hoses.
Old Jan 30, 2005 | 11:31 PM
da'Moose's Avatar
da'Moose
On my 90’ 2.3l we have had the same problem. It only happens when the outside air temp drops way off the scale. We fixed the problem with a piece of cardboard. My dad would cover the whole radiator with the card board, and I with ½ to ¾ of coverage. In the hard cold snaps the power plant just would not make enough heat. The cardboard would not cause an over heating problem running around a small town, but a highway trip or towing is a different story. We lived in northern Michigan when we experienced the problem. Now that I live in central Utah I have not ever noticed the problem, but the winters are very mild in comparison. We have replaced the T-stat many times and even replaced the radiator once. Hope it helps, Da’Moose
