No start after studs, gaskets, etc
Old Dec 6, 2013 | 10:04 AM
  #46
duck fan's Avatar
duck fan
Because racetruck
Batteries are on the charger today. It probably didn't help that it was 28 degrees last night while we were trying to start it.
Does anyone know the thread pitch on the ICP sensor? I am going to put together an air fitting to leak test the HPO system today.
Old Dec 6, 2013 | 11:41 AM
  #47
npccpartsman's Avatar
npccpartsman
M12x1.5 It's the same as the fuel pressure port.
Old Dec 8, 2013 | 07:21 PM
  #48
duck fan's Avatar
duck fan
Because racetruck
Its alive!
First I want to say thank you to everyone who gave input and offered ideas. We built a high pressure oil leak detector and there was an obvious sound coming from the passenger side head. Pulled the valve cover on that side and pressurized it again.
Turns out, when he put the engine back together after the gasket and studs on that side, he got the standpipe and dummy plugs reversed on the passenger side. That would explain no ICP.
We pulled them out and in order to get the standpipe in on that side, we had to undo the passenger motor mount and loosen the driver's side mount a bit. We then jacked up the motor to rock it over enough to get the standpipe to clear the HVAC box. Once we got it all back together, it took a little cranking and fired right up.
Lessons were learned by all. Thanks again all around.
Old Dec 8, 2013 | 07:25 PM
  #49
9228.bobcat's Avatar
9228.bobcat
Glad u got it running. The upside of all of this is you got some valuable experience on working on these trucks. You will be giving advice instead of asking.
Old Dec 8, 2013 | 07:26 PM
  #50
BLADE35's Avatar
BLADE35
That would do it
Kinda surprised the Standpipe would Fit right in the wrong spot or thread all the way in
thanks for posting the outcome
Old Dec 8, 2013 | 07:31 PM
  #51
AKPOWERSTROKE's Avatar
AKPOWERSTROKE
Good to hear. Enjoy
Old Dec 8, 2013 | 07:37 PM
  #52
jswartz84's Avatar
jswartz84
Originally Posted by BLADE35
That would do it
I was thinking the same thing.
Glad you got it running.
Old Dec 8, 2013 | 07:42 PM
  #53
npccpartsman
You can actually switch the HPO rails between sides with a little "reversing" The dummy plugs fit where the standpipes would on the other side. I don't know how they got that messed up either.
Duck Fan: It would have been easier to remove the HPO rail than the motor mounts but lesson learned.... Glad you got it running.
Old Dec 8, 2013 | 07:46 PM
  #54
BLADE35's Avatar
BLADE35
I know there reversible the Rails
Just thought the standpipe would drop down into the Branch tube
The Heads are reversible to so that Makes sense Now
I wasn't thinking of Reversable head factor
Old Dec 8, 2013 | 07:56 PM
  #55
Pocketlint's Avatar
Pocketlint
Good work folks! Glad to see you were able to get it going again Duckfan.
Old Dec 8, 2013 | 08:20 PM
  #56
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I know there reversible the Rails Just thought the standpipe would drop down into branch tube.
It does, the standpipe is technically two
Pieces and looks like a dummy plug when separated. Technically the standpipe should never be separated. When I removed the standpipe on an '07 F350, I had to pull the rail off and pull bottom half of the old stand pipe out with a pair of needle nose pliers.
That's why I was thinking the same thing, how did he did get them mixed up?
Just glad the truck is running again!
jetskiman6969
Feb 3, 2021 08:42 AM
Loftatsea
May 9, 2019 11:09 AM
GRECO
Jun 5, 2018 04:40 PM
Alight72
Oct 29, 2014 07:20 PM
drbless
Mar 18, 2014 08:49 PM
