Correct, we pulled the HPOP with the intent of changing the STC fitting but we found that it already had the updated one. But yes, everything got drained.
Work was mostly preventative. The EGR valve was wet so it was time to deal with it.
I verified LPO via the idiot gauge on the dash. I do have AE to check the parameters you listed. I am out of town till tomorrow but we will check them out and report back.
We do have at least 3 mins of cranking.
Did you replace the oring between the branch tube and the one on the bottom (suction side) of the HPOP when you reinstalled it?
There a HUEI Injector system so HPOP
Turbo charged but has a Waist gate
IDK much about 7.3L but the more I learn it seems to be similair
Well they are alot different. 7.3 has 2 valves per head and 6.0 has 4. 6.0 has vgt turbo 7.3 does not. 7.3 has 6 head bolts per cyl, 6.0 has 4. 6.0 has bed plate 7.3 doesnt. List goes on and on.
For real? Come on he just stated that they were more alike then the older 7.3s. I believe he said like twins just not identical.
