Fuel Leak
Old Nov 27, 2013 | 11:23 AM
jle70's Avatar
jle70
Fuel Leak
I have a fuel leak that is coming from a device on the filter housing. I do not know what this part is Anyone willing to let me know? lol
Please see pic, circled in red is the location of the part that fuel is coming from.
https://www.dropbox.com/s/7qw4v9yi2h8w0sk/filter.PNG
Old Nov 27, 2013 | 12:45 PM
dclack's Avatar
dclack
For some reason I can't see your picture, but it is most likely the Fuel Restriction Sensor or the Water in Fuel Sensor. Neither are required for the truck to run; so just pull it and put plug in there until you get a new one.
Old Nov 27, 2013 | 12:46 PM
jle70's Avatar
jle70
Thank you!!!!!! "#6-051 FUEL BOWL RESTRICTION SENSOR 1994.5 - 1997"
Is it common to weep fuel from this?
Old Nov 27, 2013 | 01:01 PM
dclack's Avatar
dclack
I'm not sure, but I did have one go bad on me after I rebuilt the fuel bowl. IIRC it's 1/4" NPT. So go grab a plug and stick it in there until you get a new one; or just leave it there. Some people just pull that and never replace it.
Old Nov 27, 2013 | 01:03 PM
Hussler's Avatar
Hussler
... YES ...
If it looks like this one ? Ford changed the location on 96-97 to here ...
If you have an international dealer around they are less expensive than purchasing directly from Ford.
Old Nov 27, 2013 | 01:51 PM
jle70's Avatar
jle70
Most definitely the part, what is it's purpose?
Old Nov 27, 2013 | 02:30 PM
dclack's Avatar
dclack
It tells you if you have a clogged fuel filter.
Old Nov 27, 2013 | 02:47 PM
DarkStarMedia's Avatar
DarkStarMedia
I know I am in the minority... but... I'd get a new sensor.
Then again, I also went and replace my fuel bowl heater too (mot people just remove/unplug).
I am a fan of not removing features.
Richard
Old Nov 27, 2013 | 02:54 PM
dclack's Avatar
dclack
Oh, I've replaced both of those myself. For as cheap as they are, why not replace them.
Old Nov 28, 2013 | 12:51 PM
matts156's Avatar
matts156
My WIF sensor leaked on mine. Something cracked or got loose internally and it dripped out of the sensor connector. When replacing it, don't screw it in too far. There's no positive stop for the sensor to bottom out on so it can be screwed in far enough to crack the housing.
Old Nov 28, 2013 | 01:00 PM
fordman67's Avatar
fordman67
Be very careful!!that housing is fragile and crack easily.btw its 1/8" npt.
mudrat025
Jun 27, 2013 08:06 PM
bill1954
Jun 26, 2011 09:55 PM
Tater50
37
Dec 25, 2010 07:19 PM
happeetxn
21
Nov 14, 2007 02:40 PM
gomfrddy
Nov 27, 2005 04:14 PM
