Starting issue
Old Nov 27, 2013 | 05:44 PM
HKusp's Avatar
HKusp
On the outside of the valve cover harness you will see a 9 pin connector, use the center (position 5) as the ground, ohm out the 4 at the ends of the plugs, so positions 1,2,8,9. Should all be less than 2 ohms.
Old Nov 27, 2013 | 05:45 PM
whitetmw's Avatar
whitetmw
Originally Posted by binuya
Agreed. Most important.
No FUCM on a 7.3 - DIM
Old Nov 27, 2013 | 05:55 PM
HKusp's Avatar
HKusp
Originally Posted by Tugly
Ohm test
You can pull the 42 pin connector, and OHM them here too.
Old Nov 27, 2013 | 06:18 PM
Pikachu's Avatar
Pikachu
Correct me if I'm wrong, but isn't that the pinout for the injectors, not the glow plugs?
Old Nov 27, 2013 | 06:32 PM
binuya's Avatar
binuya
Yes, IDM, not FICM. The point being we need to see at least 10.5 volts to fire the injectors.
Luke Konkel
Dec 22, 2015 06:00 PM
RedDevil460
69
Mar 22, 2014 11:39 PM
fisherman2626
Nov 29, 2010 06:55 PM
bam5464
Sep 23, 2008 10:48 AM
genbryan
Sep 17, 2008 04:27 PM
