Scangauge not reading EOT?
Old Nov 26, 2013 | 10:25 PM
Number21's Avatar
Number21
I have an 04 F350 with a Scangauge II. For some reason the EOT, boost, and a few other gauges keep disappearing. There is just no reading. If I turn off the truck and restart, they work again. Seems to happen most often when it is cold, right when I want to watch the EOT.
Does anybody know what is wrong here? I'm not sure if there is something wrong with the truck or the Scangauge?
Old Nov 26, 2013 | 11:47 PM
jswartz84's Avatar
jswartz84
Are you waiting for it to power up on its own or forcing it on?
Old Nov 27, 2013 | 05:47 AM
npccpartsman's Avatar
npccpartsman
Mine does that too. If I unplug it and plug it back in I always let it "go to sleep" on it's own before I try to start the truck. Same thing when I restart it the next time. I let it come on by itself and after a few times I can "force" it on but I never do it before I start the truck.
Old Nov 27, 2013 | 07:24 AM
Tennesseepowerstroke's Avatar
I had a Scangauge II that had a mind of its own. Sometimes it did not "wake up" even after a few miles of driving. I could always touch the button and it would come on. Scangauge replaced it and I have not had any more problems.
Old Dec 12, 2013 | 09:26 PM
Number21's Avatar
Number21
OK, I've been trying different things with it, but it still seems to just drop the EOT and a few other things randomly. Am I not supposed to power it on before I start the truck? I like to see how warm it got from the block heater before I start. If I unplug it and plug it back in it still doesn't work, I have to shut off the truck and start it again.
Think it's the Scangauge that's broken, and not the truck? I guess I'll talk to them about getting a replacement. (it's only 2 months old!)
Old Dec 12, 2013 | 10:40 PM
jswartz84's Avatar
jswartz84
Sounds like a bad SG2.
Old Dec 12, 2013 | 10:52 PM
DieselVol's Avatar
DieselVol
Sounds like both of mine. I have them daisy chained and they seem to work perfectly one time then are just plain awful the next. No real rhyme or reason. If I KOEO long enough for even the fuel pump to go off, they will work MOST of the time. Not really a very reliable set up. Really frustrating when hauling heavy.
Old Dec 12, 2013 | 11:02 PM
jswartz84's Avatar
jswartz84
Did you ever look in to an OBD2 splitter and just running the seperate cords to each unit? This would get away from Daisey chaining.
Old Dec 12, 2013 | 11:06 PM
jswartz84's Avatar
jswartz84
http://m.ebay.com/itm/120902578626?nav=SEARCH&sbk=1
Old Dec 13, 2013 | 06:10 AM
DieselVol's Avatar
DieselVol
There are a lot of threads on this site on this issue. I've not heard from anybody who has has a good experience with OBDII splitters or daisy chaining to make two work at the same time. I'm definitely open to suggestions, however.
Old Apr 12, 2014 | 11:13 AM
skytrash's Avatar
skytrash
so I'm new at this, I can't find in the instructions how to program the scan gauge 2 to read oil pressure
Old Apr 12, 2014 | 11:54 AM
npccpartsman
It will read HIGH pressure oil pressure (ICP) but not engine lubricating oil pressure since the PCM doesn't monitor that engine parameter as there isn't a real sensor for it. The dash gauge is nothing but a dummy light with a needle
Old Apr 13, 2014 | 03:57 AM
Mcrafty1's Avatar
Mcrafty1
Mine does the same thing, not often and only twice that I can remember....both times was when the truck was cold......VERY cold, like 20 below zero so I blamed it on that but if we find out something more here that would be good.
Old Apr 13, 2014 | 07:45 AM
Mine did not "wake up" when the truck was started a few times. I could push the menu button and it would come to life when this happened. Scangauge replaced mine under warranty and I have not had the problem again after 3 or 4 years.
Old Apr 27, 2014 | 12:58 PM
jmtbiggin's Avatar
jmtbiggin
I have a MIA boost gauge. I usually run EOT,ECT,FMP,TFT. I pull the boost up randomly to check. Latley a blank has been next to boost. Not "0",but a blank. Double checked programing via Ficmrepair.com and It is correct.Also the truck is very strong and turbo whistles a beautiful tune. Safe to say i may have a dud scan gauge?
Dogman_528
Nov 20, 2015 09:15 AM
X3booboo
Mar 22, 2013 02:03 PM
jchampion116
Apr 17, 2012 09:44 PM
6.0 Rules
May 2, 2008 05:59 PM
dc600slayer
Oct 10, 2004 09:54 PM
