CPS Symptoms/Issues
Old Dec 2, 2013 | 12:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by Reckless
So there's a physical difference (allegedly) between the black and grey ones? Are the grey ones used in any other engine applications to account for this difference?
The ford ones only ever used in Ford 7.3L. There is a confirmed physical difference between black and gray. I have an oem black. I dont run it though.
Sent from my Galaxy S4
Old Dec 2, 2013 | 01:29 PM
Reckless's Avatar
Reckless
Well if there was a problem with whichever, one would think a mod would be coming out on them to alleviate premature deaths.
Old Dec 2, 2013 | 05:41 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
They did. Thats why we have the grey one.
Old Dec 2, 2013 | 06:20 PM
hydro man 17's Avatar
hydro man 17
I guess I must be one of the lucky ones - so far at least. I installed the BW unit I got at
O'riley's ( I know ) but it has not failed and my engine runs better than with the "recall unit"
Tested with wipers ETC. Also picked up the dark blue and grey one from IH but I understand that the grey one should not be used due to compatibility issues. Just my .02
Old Dec 2, 2013 | 07:57 PM
t.scottNDU's Avatar
t.scottNDU
Originally Posted by pmasley
TYLER, I CANNOT FIND THE DAMN THINGS.
I had a dark grey in mine when I sold the truck. It did not seem to run right, but did not quit like the rest. I was going to use the light grey and shim it/grind it until I got around the .05 clearance I had heard about at the garage.
That's ok! I appreciate you taking the time to look. The search continues!
Old Dec 3, 2013 | 01:00 AM
pmasley's Avatar
pmasley
If I do find them, I will send you a PM so I can send them to you. As I no longer have a truck, I have no need for them.
Old Dec 3, 2013 | 02:33 AM
Dave7.3's Avatar
Dave7.3
Reading through this thread, I think I might have figured out the issue with my truck.
When I rebuilt my engine (top to bottom), I swapped out the grey Ford CPS for a BW unit. The truck has ran strong for the past ~3000 miles since the rebuild. However, I noticed it takes exactly 2 seconds of cranking no matter what. Hot, cold, sitting for a minute or a week, doesn't change. Never had any issues with wipers etc though, so I didn't think anything of it.
More recently, I've had a situation where the truck on rare occasion will crank fast but not start when hot. ICP/IPR all appear to be healthy. I can't recall if the tach wasn't moving at all during those events. I figured it was an air leak somewhere but haven't been able to track it down. Now I'm thinking it just might be CPS related... Gonna swap in my old grey CPS later this week and see what happens.
cabloom300
Jan 11, 2014 10:43 PM
Diesel 724
Jan 24, 2012 07:43 AM
countrykid_86
Apr 23, 2009 08:09 PM
Talyn
Nov 16, 2008 01:24 PM
PowerstrokeJunkie
28
Sep 8, 2006 04:17 AM
