radiator saddle - question
Old Nov 21, 2013 | 04:09 PM
DW SD's Avatar
DW SD
I'm doing some fabrication and cleanup of my chassis while my engine is out. Other thread is here showing details of the fabrication: late model electronically controlled drivetrain install - Page 5 - Ford Truck Enthusiasts Forums
Anyhow.....looks like the previous owner sectioned and cut part of the radiator saddle to install a larger (taller) radiator.
May I leave the front fenders and fascia in place and just support across the bodywork underneath with a 2x4 or 2x6 on a floor jack so I can remove the saddle to do some metal work on it? I'm hoping to not remove the fenders, though I realize not the end of the world.
I just need to borrow the saddle for a few hours to weld back in some metal.
Thank you,
Doug
Old Nov 21, 2013 | 11:25 PM
DW SD's Avatar
DW SD
Wow - no one here knows? I'm open to a guess. Sure appreciate the thoughts.
Old Nov 22, 2013 | 12:00 AM
das54's Avatar
das54
What year is your truck? I've a 54. I've not done what you're thinking but seems like it should work. I'd put the frame on jack stands and then support the fenders, maybe up thru the wheel wells. the radiator saddle (or support) will have to come out the rear. Hopefully you have room between the major engine components and the upper valance. Post back how it goes.
Old Nov 22, 2013 | 12:21 AM
DW SD's Avatar
DW SD
Hi Dan,
Thank you. No drivetrain is installed-wide open engine bay. 1951. Would rather work on the horseshoe on a bench.
Doug
Old Nov 22, 2013 | 12:32 AM
Kladd1987's Avatar
Kladd1987
Where are you located? I have a second rad support that I will not be using in good shape if your interested.
Old Nov 22, 2013 | 05:35 AM
The Horvaths's Avatar
The Horvaths
Try temporary bracing to hold the spacing.
I could've been an ad man.
Old Nov 22, 2013 | 09:14 AM
DW SD's Avatar
DW SD
👍 good idea.
Kladd,
I appreciate the offer. The radiator, I think, does not fit without removing some material from the horseshoe. It is taller than stock. I want the extra cooling capacity.
So, I think I need to modify the modified version 😃
Thank you much !!
If you are near to San Diego county glad to buy you a beer to say thank you for the offer.
Old Nov 22, 2013 | 11:22 AM
dmack91's Avatar
dmack91
It might be a good idea to put some kind of padding between the lower rock pan (under the grill) and the frame, and then do as you said and support the fenders from underneath. I know on mine it is only about 1/2" between the two and when you unbolt the saddle from the inner fenders, it will want to drop. Otherwise, I would think your plan would work.
Old Nov 22, 2013 | 03:05 PM
das54's Avatar
das54
Yea, you 48 to 52 gusy need to chime in. but the spacing between the roll pan and the frame horns is close on my 54 so some padding in there is a good idea. I've no idea how much the whole thing will move around when you cut loose the radiator support. I would also have to remove my battery tray because that is bolted to the side of the radiator support.
Old Nov 25, 2013 | 10:41 AM
DW SD's Avatar
DW SD
Thanks for the suggestions everyone! I'm out of town til this weekend. I think the bodywork would rest on the frame horns upfront. I will heavily pad that area. Pretty sure the grill will hold everything firmly together.
Doug
Pescs334
1983 - 2012 Ranger & B-Series
Sep 30, 2023 09:54 PM
Scottys-350
Feb 3, 2013 10:07 PM
john fin
Dec 13, 2011 12:30 AM
Jeff and Nicolle
Dec 22, 2010 11:10 PM
Texas80F150I6
Sep 3, 2004 09:30 PM
