Looking inside turbo exit side
Old Nov 21, 2013 | 07:20 PM
vacuumbed's Avatar
vacuumbed
Originally Posted by m-chan68
PICTURES????
Do you mean a picture of the compressor side? I now know that the exhaust side is gone. I can still post a pic of the exhaust side if you like.
This is in a 2008 E450 cutaway van that used to be an ambulance. It has 171,300 miles on it.
Old Nov 21, 2013 | 07:29 PM
vacuumbed's Avatar
vacuumbed
Meaning the engine is damaged beyond repair?
Old Nov 21, 2013 | 07:36 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Definately post some pics... that's some crazy carnage to see the turbine wheel missing.
JOsh
Old Nov 21, 2013 | 07:38 PM
Maxium4x4's Avatar
Maxium4x4
The intake side will stick in the housing, the exhaust side will spit down the exhaust... don't ask how I know.
Exhaust side on my last turbo...
Old Nov 21, 2013 | 07:41 PM
MisterCMK's Avatar
MisterCMK
All the more reason to delete the cat and muffler. You don't want that turbine wheel getting stuck in the exhaust.
Old Nov 21, 2013 | 07:46 PM
Maxium4x4's Avatar
Maxium4x4
I won't mention names but he pulled it out of the tail pipe....
Old Nov 21, 2013 | 07:50 PM
MisterCMK's Avatar
MisterCMK
I hope he used some lube digging around in that tailpipe.
Old Nov 21, 2013 | 07:56 PM
vacuumbed's Avatar
vacuumbed
Lube would be good, I bet it's pretty dry in there.
I'm still wondering how the blown turbo turned this 6.0 in to a no start.
Old Nov 21, 2013 | 08:00 PM
Yahiko's Avatar
Yahiko
What size wrench did you have to drop in to do that mess?
Sean
Old Nov 21, 2013 | 11:01 PM
Maxium4x4's Avatar
Maxium4x4
If you smoke the turbo and keep driving it..... one could start punching holes in the pistons from high EGT's. I could not drive over 45 MPH or slight grades because the temps would climb.
A no start can be anything, one would have to do the process of elimination instead of guessing.
Old Nov 22, 2013 | 06:43 AM
raptor131's Avatar
raptor131
I would start by checking compression in all cylinders. And I would not invest in a turbo until you get it running. This engine may be toast. What does the oil look like? Any metal parts in the oil pan? Are you able to check low pressure oil while cranking? To verify the low pressure oil pump is good. Any codes?
Old Nov 22, 2013 | 07:02 AM
Snowseeker's Avatar
Snowseeker
haha, these guys will get you to pull the motor, tear it completely down, and rebuild it.
Old Nov 22, 2013 | 07:11 AM
  #28
Misky6.0's Avatar
Misky6.0
bulletproof it - Ripley: "it's the only way to be sure"
Old Nov 22, 2013 | 12:27 PM
  #29
vacuumbed's Avatar
vacuumbed
On a van the oil filter housing is underneath. I pulled it and inspected the filter. It was clean. I put it back together and cranked it and it refilled. I think the LPOP is okay.
It had the anti-theft code in it, but then it cleared and didn't come back. I don't have a scangauge yet to look deeper.
Old Nov 22, 2013 | 12:53 PM
  #30
MisterCMK's Avatar
MisterCMK
This is a van we are talking about here. Checking compression is not exactly an easy thing to do on a van. If the exhaust wheel on the turbo is gone he needs to replace the turbo. Then he needs to get a scan tool and take a look at some of the live data and see why the thing won't start.
