Intermittent no-start
Old Nov 19, 2013 | 06:06 PM
howler4x4's Avatar
howler4x4
Turn key, engine cranks, but no fire. Shut off, repeat 2-4 times, finally starts & runs normally for a week or two.
Scan Gauge shows no codes. What should I look for?
(2001 V-10 with 115k miles)
Old Nov 19, 2013 | 08:08 PM
Areford's Avatar
Areford
Check out the idle air control valve on the back side of the throttle body. It may be full of carbon and can be due a good cleaning or replacement. About $60 new.
Old Nov 20, 2013 | 06:13 AM
projectSHO89's Avatar
projectSHO89
Make sure it isn't PATS-related by observing the THEFT for either prove_out or for a fault indication.
This is the time of year for sticky IAC valves to show up. You can crack the throttle slightly to imitate its function for starting to see if that helps. If it does, clean or replace the valve.
Old Nov 20, 2013 | 08:46 AM
howler4x4's Avatar
howler4x4
Good info, thanks to you both.
davalann
1983 - 2012 Ranger & B-Series
Sep 27, 2011 03:03 PM
r6mitten
Dec 12, 2010 11:36 AM
48' fordster
Oct 1, 2008 09:51 AM
preppypyro
General Automotive Discussion
Jan 26, 2006 05:36 PM
kclyki02
Mar 9, 2005 06:44 AM
