idling issues
Old Dec 8, 2010 | 04:14 PM
r6mitten's Avatar
r6mitten
idling issues
i have a 92 f150 5.0 auto with a 95 f150 5.0 motor in it. the truck has always had an idling issue but i've grown too tired of it. when i first start the truck it will run fine for about 20 seconds then will simply die unless i give it throttle. then if i start it again it will not stay running unless i give it more throttle. also when i first start it and i go into reverse, drive, etc it will die unless i give it throttle too. im thinking it needs a new idle control valve and a good throttle boddy cleaning. it has the 92 wiring harness so im leaning towards purchasing the control valve for a 92 not a 95 help please thanks
Old Dec 8, 2010 | 05:33 PM
r6mitten's Avatar
r6mitten
ttttttttttttt
Old Dec 8, 2010 | 06:30 PM
taisa899's Avatar
taisa899
check for vaccum leaks. A bad IAC usually causes a fluctuating idle. Is the motor stock or modified?
Old Dec 8, 2010 | 06:33 PM
danr1's Avatar
danr1
Sounds like your IAC valve is a pretty good guess.
If the IAC valve is stuck or dead it won't get any air. Try pulling the vac line out of the brake booster giving it a little air, see if it idles fairly decent doing so.
You can try cleaning the IAC first, take it off and look at it, see if the valve is gummed up and stuck. If it is a good flushing with carb cleaner should correct the problem.
Do not use carb cleaner on the throttle body though, if you clean it use throttle body cleaner.
Old Dec 9, 2010 | 08:33 AM
r6mitten's Avatar
r6mitten
yes the motor is bone stock
Old Dec 12, 2010 | 11:36 AM
r6mitten's Avatar
r6mitten
well i took your advice ad pulled the vac line out of the brake booster and it runs much better. so what would your next step be
dlong97em
Sep 9, 2014 10:19 AM
jejdavis
Jul 14, 2011 11:35 AM
football3295
May 8, 2008 10:58 AM
phoneman91
18
Dec 31, 2007 10:22 AM
stevieray
Jan 13, 2002 04:25 PM
