Sponsored by: Real Truck
Speedometer and shift point changes
Old Nov 18, 2013 | 02:47 AM
Ford11's Avatar
Ford11
What is the best way to adjust a speedometer on an 07 6.0L F250? Also if I wanted to change the shift points is there any way to do this with out tuning the truck? I have put a ton of time and effort into the truck and its only got 59,000 miles I plan on keeping it for many years to come.
Old Nov 18, 2013 | 03:28 AM
Yahiko's Avatar
Yahiko
I am running a SCT tuner with a set of tunes from Matt at
Gearhead Automotive Performance
You can do something simple and not stress things like the
8K tow tune it is mostly transmission or the unlimited tow tune
that is only transmission. Or if you want to really pep things up
and NOT blow it up there is the SRL. I like the 8K gives a little more
get up and go but not so much I loose MPG and with that tuner you
can adjust both shift points and speedometer.
You could always give them a call and Matt can create something just for
your truck or point you to something that will meet you needs.
They are really good people.
Also with the 6.0 you should come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Take some time to read the tech folder at the top of the forum and
you will pick up a lot of very useful info.
Sean
Old Nov 18, 2013 | 07:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The ONLY way to adjust the speedometer is with the proper tool that can access the computer and change the setting.
The ONLY way that the shift points can be changed is with a tune.
Old Nov 19, 2013 | 12:27 AM
Ford11's Avatar
Ford11
Does anyone have experience with innovative diesel? checked with gear head today and liked what I heard from them but if I am going to tune my truck I want it to be done right because I have put a ton of time, effort and money into my truck.
Old Nov 19, 2013 | 12:37 AM
MisterCMK's Avatar
MisterCMK
I tried innovative tunes. I run gearhead tunes now.
Old Nov 19, 2013 | 11:29 AM
droldsmorland's Avatar
droldsmorland
Mark Ill give you a thanks for your reply.... I like straight simple short answers. Dont all engineers?
dmitrysgarage
Oct 9, 2020 09:53 PM
69ford99
2004 - 2008 F150
Jul 24, 2011 07:46 PM
Fordxcab4x4
1997 - 2003 F150
Mar 5, 2006 05:53 PM
wagner63w
Modular V10 (6.8l)
Aug 11, 2003 03:04 PM
beachbronco
1978 - 1996 Big Bronco
Jul 2, 2002 11:49 PM
