Patch RKE module into Antenna?
Old Nov 16, 2013 | 07:23 PM
GuitarJesus's Avatar
GuitarJesus
so I bought a brand new wiring harness that includes the keyless entry module so I can put it into my truck.my friend has the same year Ford and the range on the module is pathetic.when I have gone under the dash of models with the keyless module, it is simply a wire with about 6 inches coming out of the module.
Does anyone think if I used a Y connector and patched it into the vehicle's antenna it would amplify the distance at all?
Old Nov 16, 2013 | 11:56 PM
JSchuricht's Avatar
JSchuricht
Antennas can't be changed around that easily. They are designed for a particular frequency and teeing in multiple devices when one is sheided and the other is not will cause even more issues.
Old Nov 17, 2013 | 01:09 AM
GuitarJesus
Who says one won't be shielded? I'll of course use a shielded antenna patch cable. but just like a home TV antenna, you can split the signal of a car radio antenna. Whether or not it will give any boost to the range of the wireless remote module, that I don't know.
Most North American RKE modules regardless of manufacturer run in the 315mhz range. An automotive antenna won't have much of a problem picking this up.
Old Nov 17, 2013 | 10:18 AM
Jarryd's Avatar
Jarryd
Only way to know is try.
Old Nov 17, 2013 | 04:50 PM
dixie460's Avatar
dixie460
315 Mhz is way past the 108Mhz upper design range of the factory radio antenna. It MIGHT work, but why not just make a dipole antenna or something and mount it above the headliner at the top of the cab?
Old Nov 17, 2013 | 05:22 PM
danr1's Avatar
danr1
Did you try simply adding to the antenna wire?
First couple remote starters I installed, one in my moms car one in my wife's car.
First one was moms, it include antenna with wire long enough to run up behind the A pillar trim then across over top of windshield in couple plastic stick on brackets top the glass.
Second one really expected the same (both starters same manufacture) only to find that that one had about a 16" wire for the antenna. Instructions stated to run out far as possible under dash. As expected range was pathetic with it, so I added to that wire running it up behind A pillar trim, worked great after that. I just matched the wire size soldered on more adding to the length, shrink tubing would have been ideal looks like that is what they used, I just covered the joint with little bit of black tape called it good.
Old Nov 17, 2013 | 06:49 PM
GuitarJesus
it is above the upper registers of what f_m radio puts out, but on the spectrum, that is a very small frequency bump up for an antenna not to be able to pick up. Not to mention newer antennas can pick up HD Radio and television signal as well.
Old Nov 18, 2013 | 06:40 AM
dixie460's Avatar
dixie460
HD Radio is within the same frequency range as FM... not sure on TV though.
TV can die for all I care lol. You're right, that is a small shift in frequency on the overall spectrum. It might work... I ain't an expert on radio transmissions by any means, but from what I do know... if you want a half-wave antenna it's gonna end up being close to 1.5 feet, as opposed to 6 inches like the factory RKE antenna. The length of the factory FM antenna is what, like 2 feet?
Hell try it out and let us know!
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
Dave Megill
Dec 21, 2016 09:17 PM
buffalocomputer
Escape & Escape Hybrid
Nov 7, 2012 01:02 PM
firefytr29wfd
1997 - 2003 F150
Jun 23, 2005 12:29 AM
Bassman22
Jun 16, 2002 01:04 PM
