Opinion on compression numbers
Old Nov 16, 2013 | 02:02 PM
mrberg89's Avatar
mrberg89
Well folks after owning my truck for a year I decided to finally test the compression. Here's what I found
Drivers side front to back:
390
445
425
445
Passenger front to back:
435
435
410
435
Seems good to me, but the 390 kind of bothers me. Anyone think it's a problem? I tested because I'm planning on sticking a ton of money into her pretty soon (injectors, pump, radiator, suspension) and I wanted a good base to start with.
What y'all think?
Old Nov 16, 2013 | 03:02 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I would question the lowish cylinder as well, but realistically those are pretty good numbers. I assume the test had been done after the engine was warmed up?
Old Nov 17, 2013 | 12:08 AM
ifrythings's Avatar
ifrythings
I believe ford lists it as 20 or 25% from the highest to lowest number, so by that your good to go. Haynes says 260-440psi for compression.
If you want to go deeper into it, do a leak down test to see what mite be up with that cylinder.
Old Nov 17, 2013 | 12:32 AM
mrberg89's Avatar
mrberg89
I seem to remember reading somewhere that ford says 25% difference or under.
For having at least 230k miles I think she's doing pretty good.
Old Nov 17, 2013 | 05:17 AM
BruteFord's Avatar
BruteFord
Was the cylinder that read 390 the first one you did, and how long after it had last run?
Old Nov 17, 2013 | 09:38 AM
Dieselamour's Avatar
Dieselamour
Typically, 10% variation is the rule of thumb, unless you have the manufacturer specify 20 to 25%- so you are good to go.
I am assuming this is a dry test. Edit: Do not perform a WET compression test on a diesel engine- end edit.
Last edited by Dieselamour; Nov 17, 2013 at 01:22 PM. Reason: corrected iformation
Old Nov 17, 2013 | 12:24 PM
dsltech83's Avatar
dsltech83
Do not do a wet compression test on a diesel, it can either combust or hydrolock with liquid in the cylinder.
Old Nov 17, 2013 | 01:19 PM
Dieselamour
I stand corrected. Thanks. I have performed a wet test several times and did not know this. I guess a leak down test is safer. Thanks. Edit: I guess anyone and his monkey cannot work on these trucks, lol.
traveler1234
May 10, 2018 08:20 AM
joec380
Feb 17, 2012 12:17 PM
theerod
Jan 19, 2012 06:59 AM
Danger_Dave
Feb 14, 2008 11:48 AM
Purely Ford
Oct 21, 2004 01:20 PM
