428 Compression Reading
Old Oct 21, 2004 | 09:53 AM
Purely Ford's Avatar
Purely Ford
While checking compression to isolate a problem with my 428 I was getting around 152 - 158 psi readings. Just out of curiosity, what have any of you guys gotten for readings from compression tests you have performed on your 428s.
I found a weak cylinder while testing. Number 7 cylinder has about 60 psi, so I am going to have to break it down.
Old Oct 21, 2004 | 11:05 AM
Mike G's Avatar
Mike G
Don't have a 428, but the numbers sound on the top end of reasonable for an FE.
--Mike
Old Oct 21, 2004 | 11:17 AM
Purely Ford
Thanks! Just wanted to know how the other cylinders compare to what is normal.
Old Oct 21, 2004 | 11:37 AM
Mike G's Avatar
Mike G
Shoot a little oil into that cylinder and see if it comes up closer to the rest.
--Mike
Old Oct 21, 2004 | 01:20 PM
Purely Ford
I already used the oil trick and it didn't change the compression on that cylinder. The piston is most likely damaged (hole burned through). The engine ran lean on a long trip on the highway awhile back in the summer because of a vacuum leak. Slowing down getting off of the highway I noticed a miss (not a single woman, lol) at idle and then after shutting the engine down I could hear the vacuum leak under the dash. The climate control had seperated and allowed plenty of raw air into the engine.
This engine doesn't have much mileage since it was rebuilt in 1994. Maybe 20-22 thousand miles, so it has plenty of life left in it before it needs another complete rebuild. Once I tear into it I may decide to replace all pistons and maybe do a few more updates like maybe a different camshaft.
marshallstanford
Jul 15, 2016 06:42 AM
Chisum5013
Feb 4, 2016 01:14 AM
ddeflyer
Mar 4, 2015 08:19 PM
1972RedNeck
Jun 1, 2012 07:17 PM
FE 390
13
Sep 26, 2003 08:51 PM
