MSD Heli-Core wires?
Old Nov 14, 2013 | 11:45 PM
F-250 restorer's Avatar
F-250 restorer
I'm wondering if anyone is running them, or knows the skinny about them. They seem to be the only wires I can find that say for higher power current.
I have an msd box with a tfi coil. I'm running Taylor Thunder Volt wires, 8.2mm now, but one lost the clamp on end.
Old Nov 14, 2013 | 11:54 PM
blue04.5's Avatar
blue04.5
I have black jegs Pow'r wires in 8.5 flavor they have the wound center, and truth be told are probably made by the same company. I like them I bought the make your own kit came with ends for socket style cap and HEI style cap and the plug ends can be bent up to about 90 degrees. I also have an ignition box. Sorry its not MSD specific but they are a good deal and seem high quality.
Old Nov 15, 2013 | 12:06 AM
fordrealdrive's Avatar
fordrealdrive
When you say "clamp" are you referring to the part inside the boot that snaps onto the plug?
That can be re crimped...unless you need new wires.
Old Nov 15, 2013 | 07:01 AM
fmc400's Avatar
fmc400
MSEE
What specifically is meant by "higher power current?" Power and current are two different metrics. Plug wires actually carry very low current; the gap of the spark plug is effectively an open circuit. Voltage is what matters. If you're looking for "high current" plug wires, you won't find such a thing. Moreover, plug wires are typically built from special material to make them even more resistive, for noise suppression purposes.
Old Nov 15, 2013 | 08:19 PM
Blue and White's Avatar
Blue and White
I'm running the Bosch "coil type" wires on my dent. They have low resistance and noise suppression from the coil style wire. About $35 at AZ. My system is stock but I would run them with a MSD box and stock plug gaps without concern. I wouldn't open up the gaps however... with these or any other wires as higher secondary voltage with high gaps can cause short life of the cap and rotor not to mention wires.
Old Nov 16, 2013 | 05:00 AM
slashfan7964's Avatar
slashfan7964
I'm using Accel SuperStock spiral cores on my truck, they are 8mm. Low resistance, have held up well. I'd recommend them. Ignition system is MSD with a Ford Racing distributor.
wpinef
Mar 26, 2008 10:16 AM
YoungMT Hick
Apr 10, 2007 10:40 AM
JohnAW
4 Cylinder Engines
Sep 16, 2005 08:23 PM
MemOrex
Sep 2, 2005 05:36 PM
machawks
May 14, 2004 11:19 AM
