Plug wires -460
Old Mar 25, 2008 | 06:47 PM
wpinef's Avatar
wpinef
Plug wires -460
Hi
can some one explain to me the improvements that I would get if I installed the 9 mm MSD wires or the 9.5 Ford racing wires?? Also the sticker in the engine compartment says 42 to 46 for the gap on factory plugs is there a better plug or gap setting??
Thanks
Dave
Old Mar 25, 2008 | 07:33 PM
hotrodmerc's Avatar
hotrodmerc
42 to 46 is ok for the plug gap. You won't see any difference in the wires if they both have low ohms resistance.
Old Mar 26, 2008 | 10:16 AM
mcdonaldm's Avatar
mcdonaldm
if you are asking if changing the plug wires will make any difference, then yes. i changed the plug wires on my 302 to MSD 8mm wires and noticed quite a difference in power and throttle response. not tire smoking difference, but just a difference. as long as you are changing wires, take advantage of the better wires and get a better coil for more spark.
rgds
mike
tygarcia
1978 - 1996 Big Bronco
May 24, 2004 11:12 AM
johnny1720
Dec 16, 2003 11:47 AM
fatdaddy
Jan 6, 2003 08:47 PM
dfox
May 17, 2002 01:54 AM
millbobs
Mar 30, 2001 06:26 PM
