Drip Rail Question/Resto Project
Old Nov 14, 2013 | 11:31 PM
Supercab_Max's Avatar
Supercab_Max
I was wondering if there is an easy way to to remove the actual drip? I know the chrome comes off, do you drill the spot welds out or try to sneak a cut off wheel under it I looked on youtube for a video telling how to remove, just seeing if anybody knows the easiest way to get it off or the correct way to make sure to get any existing rust out from under it.
Thanks
Max
Old Nov 15, 2013 | 08:11 AM
paredneck33's Avatar
paredneck33
Why do you want to remove them? It it is to just get rid of them then you can just simply grind away the spot welds. Just be careful you don't go all the way through the base metal. Or you'd have to break out the welder. Then just use a hammer and chisel and knock it off. If you want to remove and reuse, you'll want to get a spot weld drill bit and what is know as a seam buster. It works just like a chisel but it's thinner so you get less panel distortion when separating two pieces of metal when you need to reuse at least one of them. You can get them at any auto body supply store or from your local tool dealer. Like snap-on, mac, matco, cornwell and so on. Or you canget them online from places like autobody toolmart, or eastwood company. I prefer getting the blair spot weld cutter. And getting an extra pack of the double end cutting tips. They break very easily so be careful with it.
Old Nov 15, 2013 | 10:13 AM
gnwalker's Avatar
gnwalker
There is a diagram of how and where the rails are rails are attached to the cab on an older post in this forum. I saved it when I saw it, I'll try to post it or find the thread
Old Nov 15, 2013 | 10:24 AM
tbear853's Avatar
tbear853
You'll need to add some means of redirecting water run off from the roof or else you will likely have drips inside the door down your door panels.
The drip rails are more than worth their keep.
Im going to reuse them and ... etc ... .
Oh, it sortof read like you were wanting to shave them completely, but now "I see" .....
Old Nov 15, 2013 | 12:30 PM
Supercab_Max
Im going to reuse them and thanks paredneck33!, and gnwalker I'd like to see that post, thank you also. The info is much appreciated.
Old Nov 15, 2013 | 01:12 PM
gnwalker's Avatar
gnwalker
This isnt the pic, havent figured out how to post it from my phone yet, but search "idiots guide to shaving drip rails". Very good pics and info
Old Nov 15, 2013 | 01:47 PM
Supercab_Max
Old Nov 15, 2013 | 04:16 PM
77F250Diesel's Avatar
77F250Diesel
This should help...........
Old Nov 15, 2013 | 04:37 PM
gnwalker's Avatar
gnwalker
Thats the one I've been trying put up
Old Nov 16, 2013 | 12:23 PM
Supercab_Max
Thanks 77F250Diesel, will help me out quite a bit.
Old Nov 16, 2013 | 02:11 PM
77F250Diesel
I'm right in the middle of replacing mine on the passenger side, did the drivers last year.
Not a fun job.
Dennis
xc4jokestomper
Sep 15, 2011 05:31 PM
J2Davis
Jan 25, 2009 07:07 PM
crawlfish
Paint & Bodywork
Aug 5, 2006 11:41 PM
bjolie
Paint & Bodywork
Aug 19, 2004 01:50 PM
Biggums
Mar 4, 2002 06:37 PM
