Dash swap question
Old Nov 13, 2013 | 11:02 AM
desertwest's Avatar
desertwest
Dash swap question
Previous owner mutilated my dash for an aftermarket radio. Thinking of swapping dashes as opposed to a weld up repair. Is this a simple unbolt and remove... or is that thing welded into the cab?
Old Nov 13, 2013 | 11:28 AM
daveengelson's Avatar
daveengelson
Seems replacing dash lot more labor intensive than repair and probly cheaper. A good auto body person should be able to insert a patch and would not notice. If don't have tools, experience, and equipment suggest search for 2-3 reputable auto body shops and get a quote. I was fortunate to come by an auto body person who does excellent work at a reasonable price. Seem to recall several months back topic came up where FTE member mentioned using a spare glove box door; same contour and imagine would have to remove the skin from the backing for it to match the sheet metal to the dash. Hopefully other members will chime in with suggestions and/or advice??
Old Nov 13, 2013 | 12:09 PM
desertwest's Avatar
desertwest
Thanks Dave. I am doing a full frame off resto and have a parts truck with a perfect dash. Just didn't know if it's welded also or just bolted in. Good to know about using the glove box skin for a patch as I have several laying around! I will search for that thread.
Old Nov 13, 2013 | 01:00 PM
daveengelson
Since it's a full off frame restoration, and there's a donor truck , then it does offer the option of swapping dashes, imagine lot will be determined once cab has been removed and inspected? Take pic's and don't toss any parts until a particular projects is completed, found on several occasion the replacement part did not include some of the components to make up the assembly, and/or had to salvage an item to use as a template.
Old Nov 13, 2013 | 02:02 PM
jmf66's Avatar
jmf66
My 66 dash is welded into the cab.. patching the radio area would be easier.
Old Nov 13, 2013 | 02:21 PM
schoo's Avatar
schoo
I was going to use glove box but ended up just using 16 gage patch and body filler
don't look at the back side
Old Nov 13, 2013 | 05:15 PM
CropDusterMan's Avatar
CropDusterMan
Just patch the dash with 18 guage sheet metal...tack weld, gring, sand.
Old Nov 13, 2013 | 10:25 PM
oldford65's Avatar
oldford65
Im thinking of using auto body glue on mine
Old Nov 14, 2013 | 09:33 PM
garbz2's Avatar
garbz2
Get rid of all the holes.
Garbz
Old Nov 15, 2013 | 06:14 AM
MNTBUGGY's Avatar
MNTBUGGY
I used the skin off a spare glove box on mine. It had the same contour as the dash.
Old Nov 15, 2013 | 08:42 AM
Bill W's Avatar
Bill W
I cut up a good glove box door just to find the door is made of thinner metal than the rest of the dash. i found it easy enough to weld in a filler panel as others did, just use the correct gauge material to do so.
Old Nov 15, 2013 | 05:47 PM
gangstakr's Avatar
gangstakr
As Garbz said, fill in all the holes.
Old Nov 15, 2013 | 06:14 PM
desertwest's Avatar
desertwest
Yep! Looks like filling ALL the holes is the way to go... that looks great, Gangstakr! Probably make the guys at VintageAir happy too!
351Cleveland C4
Jan 9, 2014 12:13 PM
Jonas1022
Aug 2, 2007 01:25 AM
cole1
Jul 18, 2006 10:25 AM
sancochojoe
Jun 30, 2006 08:57 AM
Fordman65
Jun 13, 2003 04:23 PM
