Dash removal in 59......help
Anybody know what is required to remove the dash from the cab of the 59? I've found a perfect unmolested donor with the factory radio opening in a junk yard (even has the radio but tuning **** doesn't work) for $100. Does it unbolt or is it a rivited cut and remove project????? My current dash has a major hole in the front for a indash radio and is a major weld and grind project. If you guys gimme' the right answer this could save me lots of time and cussing!
Received 1,364 Likes
on
It might be easier to cut a repair panel out of the new dash and weld it into the old.
As to the radio there is likely a pully and belt arangment that moves the dial on the face when the tuner is moved. Often the "belt" breaks or slips off, even tho the radio still plays.
You can also have radios repaired, or modern electronics stuffed into the old housing.
davidtabercrombie
06-01-2016 10:14 PM
MRCSUSN2007
01-10-2014 08:14 AM
johnmel59
20
01-02-2014 09:02 PM
