ac removal question
Old Nov 12, 2013 | 06:09 PM
79sparky's Avatar
79sparky
ac removal question
in my 85 f250 6.9 I wanna removethe ac unit from the fire wall since the po removed everything else and its in the way of moving my turbo. thanks
Old Nov 12, 2013 | 07:52 PM
Gary Lewis's Avatar
Gary Lewis
Ok. Go for it. You have my permission.
Old Nov 12, 2013 | 08:44 PM
79sparky's Avatar
79sparky
Haha whoops forgot to add the question. can you remove it solely from under the hood?
Old Nov 12, 2013 | 08:56 PM
Gary Lewis's Avatar
Gary Lewis
If you do that you won't have a heater as they are integrated - assuming you have factory A/C. I don't know if you can retrofit a non-A/C box, but I'm pretty sure if you do you will have large holes to plug.
Now to removing it - I'm fairly confident there are some screws on the inside or in the plenum that need to be removed.
Old Nov 12, 2013 | 08:59 PM
79sparky's Avatar
79sparky
Oh nice can'tbe simple can it, just had the whole dash off to last week for a manual conversion.
Old Nov 12, 2013 | 09:04 PM
Gary Lewis's Avatar
Gary Lewis
You had the whole dash off to go from auto to manual tranny or vice versa? Did you discover the dash itself doesn't have to come out to do that???
Old Nov 12, 2013 | 09:07 PM
79sparky's Avatar
79sparky
auto to manual and did not see any other way to get the pedal assembly out.
Old Nov 12, 2013 | 09:21 PM
Gary Lewis's Avatar
Gary Lewis
I converted one from auto to manual and one from manual to auto in the last year - both with out removing the dash. The pedal assembly bolts through the firewall to the brake master cylinder, and to the dash at the steering column. You do have to take the column out, but not the dash.
Old Nov 12, 2013 | 09:28 PM
79sparky's Avatar
79sparky
Yeah I couldn't drill out the firewall either with out removing it because of the turbo and not being able to get straight on with the hole saw. when I took the pedal assembly out of the partstruck I didn't know how it came out and being in such a hurry didn't think it through afterwards. Oh well it's done now
Old Nov 12, 2013 | 10:18 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The under dash portion of the heat only, and heat & A/C systems are totally different.
With factory A/C, the under dash stuff is vacuum controlled. With the heat only setup, it's all cable operated.
Can it be swapped? Yes, but it's not simple. You really need a complete donor to get the entire system from, including the control panel and wiring. May also need to cut/fill holes in the firewall as needed.
Old Nov 13, 2013 | 05:53 AM
Franklin2's Avatar
Franklin2
The easy way to do this is find a non-A/C truck that is a later model, I know 89's are this way. They configured the later non-A/C trucks like the A/C trucks, so all you have to do is get the later housing and bolt it in your truck. The heater core stays in the same place as it is now.
Old Nov 13, 2013 | 07:25 AM
79sparky's Avatar
79sparky
Alright thanks I know my junk yard of choice has a few of those ill look at that
Spktyr
Jul 9, 2014 10:24 PM
Jim43
Nov 28, 2010 05:24 PM
dwrestle
May 8, 2009 05:32 PM
