Quick AC Question: How to undo this?
Old Jul 8, 2014 | 07:58 PM
Spktyr's Avatar
Spktyr
Working on my truck's AC outside before the light goes away. Pretty much have it all torn down, trying to remove the last of the hoses but ran into a snag.
Are either of the indicated points a Ford quick disconnect? It doesn't look like one I've seen before; I don't seem to be able to remove the hose as it seems to be stuck at this point and my manual is no help. How do I remove it? Thanks for any help.
Old Jul 8, 2014 | 08:05 PM
timbersteel's Avatar
timbersteel
Yep, need an AC/Fuel line disconnect tool. O'Reilly, Advance Auto, Autozone all have them. Its 3/8 or 7/16 size.
Old Jul 8, 2014 | 08:08 PM
Spktyr's Avatar
Spktyr
Okay, thanks. I thought this system didn't have any, must have overlooked it. IIRC, Ford calls for the plastic tab (which seems to be missing on mine) to be replaced after disconnecting a quick connect. Are these carried at the usual parts chain suspects as well?
Old Jul 8, 2014 | 08:44 PM
timbersteel
Didn't know it had a plastic tab. Oops!
I don't know if they do.
Old Jul 8, 2014 | 09:17 PM
F350 1990's Avatar
F350 1990
When you get the tool you're going to first "clamp" it over the coupling, then push the tool towards the Cage Opening (containing the Garter Spring), you'll then pull the male and female apart...........
It's always a good idea to replace the o-rings on the coupling along with the Garter Spring...........
BTW --- the disconnect tools at AutoMoan, etc are junk...........
Old Jul 8, 2014 | 09:48 PM
Spktyr's Avatar
Spktyr
I am not unfamiliar with quick connects, just this one looks different than any I've seen before. I do have new O-rings to put in, but where do I get the retaining clip and garter spring?
Old Jul 9, 2014 | 10:17 PM
impish's Avatar
impish
Tip: Be absolutely certain the new O-rings are of the correct material for this application. Plain old black (usually) O-rings are made of a material called Buna-N, or Nitrile Rubber. A/C systems use a polyol-glycol lubricating oil, one name brand is Emkarate, and the stuff will EAT Buna-N O-rings.
Similar advice for O-rings used in fuel lines. Gasoline eats Buna-N, too. Plus, gas often now has Ethanol added, bad for plain old O-rings.
One more tip: The tools for releasing those pesky quick-connects are of varying materials: some are plastic, which often is so soft, it fails to expand the captive garter spring adequately, making separation of the parts a devilish feat. The best I've seen are made of metal. impish
Old Jul 9, 2014 | 10:24 PM
Spktyr's Avatar
Spktyr
I already have them apart, the plastic tools I kept around worked one more time. As for the O-rings, been there, done that, walked out when my friend's VW ground to a halt because a mis-specced O-ring failed and allowed ATF and coolant to mix whilst out in West Texas, in the summer on one of the hottest days of the year. :P
I usually use uprated O-rings where ever possible as I find OEMs usually cheap out on them. I certainly wouldn't use the black ones in an R-134A system. They were 'okay' when we used oils like ester and refrigerants like R-12, but not so much any more. Green rings all the way now.
Managed to get a replacement spring at the local specialty shop that rebuilt my hose assembly so that question is answered too.
Nick92515
Aug 5, 2016 09:24 PM
frdmrckr
Michigan Chapter
Jun 8, 2013 08:25 PM
bnmc98
1983 - 2012 Ranger & B-Series
Jul 25, 2010 01:00 PM
Ranger73
Dec 29, 2006 09:04 PM
Doubleclaw
Sep 24, 2003 02:51 AM
