trailer plug/ ibc issues
Old Nov 13, 2013 | 03:57 PM
  #31
SpringerPop's Avatar
SpringerPop
Be sure that wire is about ten-gauge, and fine-stranded.
Pop
Old Nov 14, 2013 | 12:25 PM
  #32
kevsimons's Avatar
kevsimons
Ok still no power to brakes at the plug. I did some more testing. When I manually activate brakes I get about 12 volts to blue wire at back of controller but when I use the brake pedal I only get about 3volts and I still get trailer disconnected display even with trailer hooked up. Any ideas?
Old Nov 14, 2013 | 03:41 PM
  #33
RV_Tech's Avatar
RV_Tech
Yes, your controller is working. Leave that part alone. I am betting you have a connection issue. Since you know you have power from your controller, if you truly have nothing at the seven pin on your truck, you have a broken connection between the controller and the seven pin (but that is almost never the case.) Using only the manual slide to do testing, verify that you have nothing to feeding the brake pin at the back of your truck.
Steve
Old Nov 15, 2013 | 04:27 PM
  #34
kevsimons's Avatar
kevsimons
Thanks for every ones help. I ended up running a new wire from controller to lug and it works great.
Boatdude60
May 15, 2023 05:08 PM
56Jimmy
All Things Towing
25
Feb 21, 2019 06:00 PM
mkenngen
All Things Towing
Jan 27, 2010 07:17 PM
F-250beast
All Things Towing
Dec 29, 2007 07:19 PM
bigreddog
All Things Towing
Sep 16, 2004 05:58 AM
