yet another tire size question
Old Nov 10, 2013 | 05:27 PM
milehi_350's Avatar
milehi_350
Sorry guys I know this has been covered several times before. My searches have come up empty though. I will be installing a leveling kit next weekend and I have my new 18's in the garage. What is the biggest tire I can fit without having to modifying the bumper or fender liner?
Old Nov 10, 2013 | 11:48 PM
scotttahoe's Avatar
scotttahoe
from what I have read you can fit a 35" tire on their but might have some rubbing going on when you have the wheel turned all the way left or right from the tire to the leaf spring. On the back no problem. A 33" may be the way to go.
Old Nov 10, 2013 | 11:50 PM
BWST's Avatar
BWST
Got Data?
I think 33" is about the limit, but maybe more with leveling. Stock is 31", I think. I was levelled (front add-a-leaf), and had 285's (33" OD) on the stock wheels with no rubbing. Pulled the leaf, and still have no rubbing lock to lock. Your 18"s might be a different story depending on what offset they have. I've seen some wheels with offsets to allow for larger tires on stock or slightly lifted rigs.
Old Nov 11, 2013 | 06:37 AM
Superduty ROCKS's Avatar
Superduty ROCKS
I just put 35" on stock rims with a leveling kit. Fills out the wheelwell, and looks great, no problems rubbing as of yet. Got nittos from tirebuyer.com, made in USA.
Old Nov 11, 2013 | 11:26 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Depends on the backspacing, I have 35's on aftermarket 16x8's with no problem. I had a friends stock '05 18's on for a few days and they rubbed like crazy on the springs.
Old Nov 11, 2013 | 08:23 PM
milehi_350's Avatar
milehi_350
Thanks for the responses guys. I was going to go with 305/60/18 but I want as much height as possible so I think I'll go with 275/70's. Mickey Thompson atz's.
Old Nov 11, 2013 | 08:43 PM
JT250's Avatar
JT250
What size were those exactly. My 305/55/20 nittos rub the liner when turning.
Old Nov 12, 2013 | 10:33 AM
cps's Avatar
cps
I believe 275/65R/18 are very close to 33" over all dia. this will give you enough room for some wheel travel without having to modifiy anything. You could probably go a little bigger but you might rub on compression of the suspension or on full turn.I have the 275s and they are fine.
Old Nov 12, 2013 | 07:14 PM
Superduty ROCKS
315/75-16 10 ply.
My zone leveling kit made it sit too high in the front for me, so I put blocks in the rear from a F-350. Now it has a slight rake, and the tires fill the wells out nicely.
Old Nov 13, 2013 | 08:28 AM
JT250's Avatar
JT250
315/75-16 10 ply.
I have the leveling kit and 350 blocks as well. I was wondering if I could go up to 315's on my 20's. My back spacing is prob different though. I might also try 295/60/20 for a little more height and less width.
stangDiesel
Sep 27, 2018 05:51 PM
kylant
Sep 26, 2017 10:55 PM
V10man
2004 - 2008 F150
Jul 18, 2011 08:42 PM
cdrmotorsports
Aug 20, 2009 07:52 PM
offroad17
2004 - 2008 F150
Nov 28, 2008 08:36 PM
