Door locks
Old Nov 10, 2013 | 01:06 PM
7.3 Rocket's Avatar
7.3 Rocket
Door locks
Power door locks 99.5 XLT both door locks had an interesting failure at the same time.
Both lock just fine with the button from either side, however neither side unlocks with the button from either side. Happened at the same time.
Ideas?
Bad GEM?
Old Nov 10, 2013 | 02:02 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Hey Pete, Are you keyless entry? If not looking at the 99 prints i don't see the door locks going through the Gem
Old Nov 10, 2013 | 07:40 PM
7.3 Rocket's Avatar
7.3 Rocket
Power locks w/o keyless. Just curious to me that the unlock failed simultaneously both sides. Originally I thought it was just the switch but both switches lock but fail to unlock the doors. Got me curious as to what is going on as I sincerely doubt the unlock side of both switches failed while the truck was parked for the week.
Old Nov 10, 2013 | 07:57 PM
Skill_Kills's Avatar
Skill_Kills
Id check over the wires by the door hinges. My dad's 99.5 had a similar problem and it was a broken wire going to the passenger door. My guess is a wire is shorting out and therefore not sending voltage when hitting the unlock
Old Nov 10, 2013 | 08:47 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here Pete, see if this helps you.
Haleyinthevalley
Jan 18, 2024 11:30 AM
Nite Ranger
1983 - 2012 Ranger & B-Series
May 31, 2010 12:13 AM
gjnicholas
1978 - 1996 Big Bronco
May 7, 2010 08:53 PM
utjer
Jan 2, 2010 08:16 PM
