fuel leaking from intercooler boot?
Old Nov 9, 2013 | 02:08 PM
cbsbuilder's Avatar
cbsbuilder
hey there, thanks in advance, i have a 02 f350 7.3. have started loosing fuel from where i think is the cold side boot of inter cooler (passenger side, just below battery) any ideas on what this could be? seems like under pressure or driving this area dumps a fair amount of fuel, not so at idle and it has taken me some time to find source as the fan has sprayed fuel every where, fairly new to power strokes but pretty comfortable with most wrench jobs.
thanks again
Old Nov 9, 2013 | 02:36 PM
jasonc76's Avatar
jasonc76
Check the valve on the back of the fuel bowl. It's got a yellow handle and is used to drain the fuel bowl. It leads to a metal tube on the passenger front side of the block. The orings go bad and cause leaks on occasion.
Old Nov 9, 2013 | 02:41 PM
cbsbuilder's Avatar
cbsbuilder
thanks jasonc definitely not coming from fuel drain, there is a boot coupling just below passenger battery, i observed a consistent drip from this area when truck was off
Old Nov 9, 2013 | 02:53 PM
jasonc76's Avatar
jasonc76
Your talking about the 3-4" aluminum fitting with the blue boot from the intercooler? There definitely shouldn't be fuel in those tubes but sometimes oil accumulates and i suppose that could leak out. The only other thing I could think of would be condensation from the a/c lines or a leaky radiator bottle. Your sure it's diesel leaking?
Old Nov 9, 2013 | 03:10 PM
cbsbuilder's Avatar
cbsbuilder
none of the above i just discovered that my radiator res is full of fuel and thats where the fuel is coming from, radiator reservoir is full and over flowing any ideas on this new development?
Old Nov 9, 2013 | 03:13 PM
jasonc76's Avatar
jasonc76
Uh oh. Injector cups. Try the forum search tool. Tugly has some detailed write ups on dx and replacing them.
Old Nov 9, 2013 | 03:16 PM
cbsbuilder's Avatar
cbsbuilder
before i search is that a big uhoh or one of the other kind? thanks for your input
Old Nov 9, 2013 | 03:21 PM
jasonc76's Avatar
jasonc76
Its fairly involved and time consuming to do, pull both valve covers, pull the injectors, remove the old cups with the puller tool, clean sealing surfaces, install new cups, allow time to cure, pressure test coolant system, flush coolant system, and put it all back together. I'd be bummed.
On the plus side I think it's fairly cheap if you can borrow the specialty tools from someone.
Old Nov 9, 2013 | 03:31 PM
cbsbuilder's Avatar
cbsbuilder
bummed is a good word, just sold a cummins cause i got sick of working on the dodge part of it, great engine, sh#t truck, now this... oh well it's only time and money right? i got lots of time. thanks again for your help
Old Nov 9, 2013 | 04:35 PM
HD Rider's Avatar
HD Rider
Clay at riffraffdiesel.com has the cups, sealant, and rents the tool.
Riffraff Diesel: Motorcraft 7.3L Injector Cup Kit
Old Nov 9, 2013 | 04:51 PM
cbsbuilder's Avatar
cbsbuilder
thanks hdrider, i live in nor cal, i think i might just pay to have this one done
Old Nov 10, 2013 | 08:47 AM
Tugly's Avatar
Tugly
It's time-consuming. You'll pay waaay more for the labor than the parts. Parts/supplies to do all 8 (properly) are about $250, and that includes the tool rental. I'm not saying you should tackle this, as I wouldn't wish this little chore on anybody... but good luck finding anybody to do it without thoroughly hosing your wallet down.
BSTW is a great resource, he re-did his 7 times and knows all the things to avoid. I had great success with mine, but I made one mistake on one cup and I tried to get away with it. It came back to haunt me and the redo was painless, once I followed my correct procedures.
Old Nov 10, 2013 | 02:06 PM
hydro man 17's Avatar
hydro man 17
cbsbuilder- Where in N. Cal are you? Have had good experience with one shop in Redding and reccomendatons on a couple of others.
Old Nov 10, 2013 | 08:59 PM
cbsbuilder's Avatar
cbsbuilder
, thats what i figured, short on parts long on labor im on the north coast, i have a great shop here in fort bragg i just have to prepare for talking with them tomorrow. this is all great advice, awesome site
FireHawk4
Oct 20, 2012 11:24 AM
njwilliamson
Sep 28, 2012 09:58 AM
clbostian
Oct 10, 2010 11:09 AM
afonda
16
Dec 1, 2008 08:08 PM
bhiggins
15
Oct 25, 2006 12:18 PM
