Dizzy help
Old Nov 7, 2013 | 10:55 PM
Ianknightley's Avatar
Ianknightley
Dizzy help
Well I've heard from different sources that the base of my dizzy(distributor) should be flush with my block, and it doesn't look like that on mine, it's probably the reason it misfires when I tighten the clamp. Is it normal that mine isn't flush with the block? It's a '72 F100 4x4 390 ... And it has power steering... Which is odd for a '72
Old Nov 8, 2013 | 10:43 AM
JEFFFAFA's Avatar
JEFFFAFA
Dizzy's are flush with the block 100% of the time. That's to keep them tight so timing does not change. As stated by myself and others on your other thread this weekend you need to pull that Dizzy and inspect to see what your PO did or didn't do. MARK the Dizzy and rotor position BEFORE removal so you can re-install with the ignition timing then being the same.
Old Nov 8, 2013 | 11:30 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by Ianknightley
Well I've heard from different sources that the base of my dizzy(distributor) should be flush with my block. (intake)
If it's the correct dizzy/oil pump shaft the flange will sit approx. 3/16" above the intake...
Old Nov 8, 2013 | 04:04 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I must need to get my eyes checked! Looks like it's seated to me.
Old Nov 8, 2013 | 04:46 PM
Ianknightley
Ok thanks everyone, I really appreciate the help... I'm a bit retarded when it comes to distributors. Pulling it out today
Old Nov 8, 2013 | 05:52 PM
JEFFFAFA's Avatar
JEFFFAFA
Don't forget to mark the housing in relation to wher the rotor is pointing. This will get you close ignition timing when you re-install the Dizzy. You eill still need to check the timing when you are done with a timing light.
Old Nov 8, 2013 | 10:07 PM
Ianknightley
Pics of the dizzy
Old Nov 9, 2013 | 10:18 PM
orich's Avatar
orich
what's the p/n on under side? Clean it up look for some type of damage..orich
Old Nov 10, 2013 | 12:05 AM
Ianknightley
Crap.. Too late on the p/n. I looked for damage, it looked fine, no missing teeth or anything. So I figured it was fine, so I put it back in and holy ****, it was a pain. It wouldn't go all they way, so I put a little grease on the end, and tapped it lightly with a mallet and it went it. I think I'm going to upgrade with an electric dizzy.
Old Nov 10, 2013 | 12:22 AM
orich's Avatar
orich
Aw nono hitting on it. Some guys put a long breaker bar & socket and turn the crank back & forth until the oil rod lines up then it will drop in place seated. You could break the dizzy teeth or the cam teeth doing what you did.
That's Another fords screw up design. common problem to reinstall.
Me, I just bump the starter push down on the dizzy a little & it drops into place...orich
Old Nov 10, 2013 | 07:18 PM
Ianknightley
Aw nono hitting on it. Some guys put a long breaker bar & socket and turn the crank back & forth until the oil rod lines up then it will drop in place seated. You could break the dizzy teeth or the cam teeth doing what you did. That's Another fords screw up design. common problem to reinstall. Me, I just bump the starter push down on the dizzy a little & it drops into place...orich
I did very light taps, and it fell in just fine, just pulled it out again, I'm just going to re-time the dizzy, I already put the motor at top dead center, how do I align the rotor?
Old Nov 10, 2013 | 08:03 PM
orich's Avatar
orich
Ez way is put a ink mark on the dizzy base with the cap on, making a mark on the housing with a felt pen lined up while cap it on to find #1 where you point the rotor when the dizzy cap it off when reinstalling the dizzy.
The Points fire juice too plugs when points Open ok not when they close. Even if it's like one tooth off most of the time you can turn the dizzy enough to get it correctly timed
right..orich
Old Nov 11, 2013 | 01:28 AM
Ianknightley
Ez way is put a ink mark on the dizzy base with the cap on, making a mark on the housing with a felt pen lined up while cap it on to find #1 where you point the rotor when the dizzy cap it off when reinstalling the dizzy. The Points fire juice too plugs when points Open ok not when they close. Even if it's like one tooth off most of the time you can turn the dizzy enough to get it correctly timed right..orich
Okay.. Re installed the dizzy with no problems. Timed and all plugs and wires re installed. I will start in the morning and see how she sounds. Should there be any up an down play with the shaft of the dizzy?
Old Nov 11, 2013 | 03:44 PM
JEFFFAFA's Avatar
JEFFFAFA
Yes. There is a little when Dizzy is out of the engine.
Justin Braun
Mar 29, 2019 05:19 PM
Tuttle69
May 23, 2014 02:32 PM
Forest_54_Ford
Aug 13, 2012 08:09 PM
Fat Diesel
General Automotive Discussion
18
May 5, 2010 09:56 AM
48fordcoe
Apr 25, 2009 11:00 PM
