no throttle
Old Nov 7, 2013 | 08:26 PM
mknapik's Avatar
mknapik
Unhappy no throttle
OK so here's the run down. Started truck this morning everything was fine drove about a hundred miles to and from my job. Got home and parked the truck everything was still fine. Come out about two hours later truck started up fine and went to back up to garage to load up tools and there no go . So I popped hood to see if the throttle cable had broke and it hadn't. Went to move throttle with my hand at the injection pump and couldn't any suggestions or a way to fix this. Thanks any help is appreciated .
Old Nov 7, 2013 | 08:43 PM
mknapik's Avatar
mknapik
OK so a lil update shut truck off after fuming for a bit and went back out and can move it now but not while truck is running what it could be is beyond me. Is it a possibility of vapor lock or something similar.
Old Nov 7, 2013 | 09:16 PM
Chevy_Eater's Avatar
Chevy_Eater
Are you saying that you cannot physically move the throttle at the IP when the truck is running??
Old Nov 7, 2013 | 09:21 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Thats a first for me... gotta be something internal
Old Nov 7, 2013 | 09:24 PM
Chevy_Eater
Yeah, if that's what he's saying that has to be a very broken IP....
Old Nov 7, 2013 | 09:25 PM
mknapik's Avatar
mknapik
Yes Chevy that's what im saying has me stumped . IP is only 40,000 miles old its a reman with a caterpillar sticker on that the previous owner had put on .
Old Nov 7, 2013 | 09:29 PM
Chevy_Eater
I'd disconnect the throttle cable and cruise cable and check it again just to eliminate everything else. If it still does it then something has to be broken inside that IP.
Old Nov 7, 2013 | 09:30 PM
mknapik's Avatar
mknapik
Ok next question is are there any recommendations on where to good a good reman from or
Old Nov 7, 2013 | 09:33 PM
mknapik's Avatar
mknapik
I disconnected the throttle cable while running and still couldn't move it but could while not running now I'm re lost
Old Nov 7, 2013 | 09:41 PM
Chevy_Eater
pumps
He's a member here, knows his stuff and has a good rep.
There are cheaper ones out there, but with widely varying opinions on quality.
I've not had to replace an IP myself, (yet), so I have no personal experience to relay on the topic.
Old Nov 7, 2013 | 09:53 PM
Macrobb's Avatar
Macrobb
Take the top off. Take a look inside. It's only two screws, and you can see how the lever interacts with the top of the pump.
Old Nov 7, 2013 | 09:57 PM
mknapik's Avatar
mknapik
I'll take a look at that tomorrow robb gotta get to bed work comes early.
Old Nov 7, 2013 | 10:04 PM
hairyboxnoogle
Be careful puttin the top back on, i dont remember the specifics but you can easily put them on wrong and redline the engine on startup, bypasses the governor.
Old Nov 8, 2013 | 08:04 AM
JHoffman93's Avatar
JHoffman93
To put the top back on you need to rig up a hot wire to the solenoid and ground the top. Energizing the solenoid in the top puts everything in its proper place.
Old Nov 8, 2013 | 08:55 AM
hairyboxnoogle
Hehe sounds like i got lucky then.
