no throttle
Old Nov 8, 2013 | 09:24 PM
mknapik's Avatar
mknapik
I was busy today replacing hot water and haven't had time to look at truck. Where exactly do I hook up the jumper wire to the solenoid in the IP and any pictures or diagrams would help.
Old Nov 9, 2013 | 04:44 PM
JHoffman93's Avatar
JHoffman93
I don't remember which connector is for the fuel shut off solenoid, just plug each one in until you see the solenoid activate. Before you start the truck remove the air cleaner and have a clip board handy, if you don't get it together right it will go full throttle and you won't be able to shut it down. If this happens all you have to do is lay the clip board over the intake and it will kill the engine. I've never had this happen to me personally but I've heard stories and you want to be prepared before hand rather then scrambling for something while the truck is screaming full throttle.
Old Nov 10, 2013 | 07:36 PM
mknapik's Avatar
mknapik
Thanks for the info and I got it fixed and what caused it is a mystery . So here goes. I took the air cleaner all the way of and was looking over everything very carefully now that it was daylight and the piece that the throttle cable hooks to was very sticky and seemed gummed up so it hit it good with degreaser and it moves smoothly now . But at the same time I'm have to run water over the IP to get it to start now when its warm this just happened so my question I have 90,000 on pump and I read all over that at about a hundred thousand they should be replaced along with injectors . How long will the pump last like this . I need about a month is that doable. Thanks again
Old Nov 11, 2013 | 05:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is a tough one. it may work like that for a year, or it may die completely tomorrow.
Old Nov 11, 2013 | 05:43 PM
mknapik's Avatar
mknapik
Talking
Hopefully not the latter of the two. Hopefully weather will stay rain free and next weekend maybe the Money tree will be in full bloom haha.
Hillbillyhotrod
Mar 30, 2010 11:12 AM
shuptyler
2004 - 2008 F150
Jan 30, 2010 01:45 PM
bigern6697
Jan 24, 2010 11:01 AM
bsmotorsports
26
Jan 28, 2006 01:17 PM
