T case shifter.
Old Nov 5, 2013 | 11:09 AM
Mike1's Avatar
Mike1
T case shifter.
So following one of the threads on here about removing and rebuilding the T case shifter. Mine will not shift into 4LO. I've removed it from the truck. (95 F250 XLT). I've sprayed it, beat on it, I even drilled a 1/4" hole in top of it for a zerk but I sprayed PB blaster in it to loosen it up. This thing will not come apart and if I beat on it any harder I'm afraid I'll just break it anyway. So here's a link on Ebay. Do you guys think this is a pretty good unit to buy as a replacement?
Thanks
Ford 4WD 4x4 Transfer Case Shift Shifter Linkage New F 150 F 250 F 350 Bronco | eBay
Old Nov 5, 2013 | 11:19 AM
DBD7's Avatar
DBD7
when I replaced my clutch I removed my shifter and found that it was also stuck. so I sprayed it well and beat on it. I got it to move but then broke off the pin keeping it from going to 4Lo and now it works fine execpt that I have to know if I am in 4hi or lo by where the handle is.
Old Nov 5, 2013 | 11:24 AM
dixie460's Avatar
dixie460
I think the pre-92 shifters will fit, and they don't break as easily as the newer ones do. You can spot a pre-92 shifter by the gate mechanism. The newer ones you have to push down to get past 4H, the older ones you move the stick sideways.
If mine breaks, I'll be going this route. Hell I might even replace it anyway, as PM.
ferrousFord
Jul 20, 2015 08:57 AM
djmichael24951
Mar 24, 2014 08:54 PM
Mike1
Aug 20, 2013 08:56 PM
brown 4x4
Dec 1, 2005 04:01 PM
bass4163
Jun 30, 2005 11:13 AM
