Sponsored by: Auxito
Truck stalling
Old Nov 5, 2013 | 09:23 AM
AFordMan's Avatar
AFordMan
Red face Truck stalling
I have a 97 F150 with a 4.2. It has started to surge or stall out when I slow down sometimes. It doesn't do this all the time. I replaced the fuel filter about 2 mths ago and replaced the fuel pressure regulator then also. Would the tps have anything to do with it? I haven't had a scan done yet. Thought I would try here first because at one time someone has removed the two cats and the check engine is on all the time.
Old Nov 5, 2013 | 11:21 AM
Bluegrass 7's Avatar
Bluegrass 7
Your close.
Clean up the IAC (intake air controller) first.
Good luck.
Old Nov 5, 2013 | 10:24 PM
MarkFord34's Avatar
MarkFord34
It also wouldn't hurt to check for a vacuum leak
Old Nov 6, 2013 | 06:50 AM
Spotty's Avatar
Spotty
Mine was doing the exact same thing yesterday until it warmed up. I know it's the IAC because I will tap on it and she levels out and is fine. It's been sporadic for about 5 years I just have ignored it because it may go months and be fine.
Old Nov 18, 2013 | 01:39 PM
AFordMan's Avatar
AFordMan
I installed a new IAC over the weekend. After driving it for a day it is still doing it. I found a larger vacuum line that comes up from the bottom of the motor. It looks like it hooks to the passenger front fender but from there I can't find where it hooks in to the vacuum system.
VONxRUBENxLA
Aug 2, 2011 02:10 AM
Thummmper
1997 - 2003 F150
Jan 31, 2011 02:51 PM
nagasaurus
1997 - 2003 F150
Jan 17, 2009 03:22 PM
Blackmutt
1997 - 2003 F150
Nov 11, 2006 06:04 PM
bcsbadboys
Aug 14, 2002 04:40 PM
