shutting off??
Old Jul 31, 2011 | 07:14 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
shutting off??
so now my truck is shutting off. it will randomly shut off now in drive. it shuts off every time i shift into reverse. i changed the egr, fuel pressure regulator, and fuel filter. and i checked the fuel pressure today and it was about 33-35 psi
so what else could be my problem. could the fuel pump cause all this?
Old Aug 1, 2011 | 02:59 AM
Slip ford man's Avatar
Slip ford man
Could be a lot of things, are you still getting any codes. What year truck is it...in general I would suggest a full tuneup, and to check the IAC, does not sound like a fuel pump problem, could be as simple as an air filter, or PCV, dirty IAC, or a vacuum line...here is a link
Ford Fuel Injection » Idle Air Bypass (IAB)
Old Aug 1, 2011 | 07:15 AM
VONxRUBENxLA
Originally Posted by Slip ford man
Could be a lot of things, are you still getting any codes. What year truck is it...in general I would suggest a full tuneup, and to check the IAC, does not sound like a fuel pump problem, could be as simple as an air filter or PCV dirty IAC or a vacuum line
is there a way to check the IAC to see if it is bad??
Old Aug 1, 2011 | 07:38 AM
rla2005's Avatar
rla2005
Look at the bottom of the page: Ford Fuel Injection » Idle Air Bypass (IAB)
Old Aug 1, 2011 | 08:53 AM
VONxRUBENxLA
easy enough to check. so next question how do i clean it?
Old Aug 1, 2011 | 02:49 PM
rla2005's Avatar
rla2005
From another forum: IAC Cleaning - FSB Forums
Old Aug 1, 2011 | 07:58 PM
VONxRUBENxLA
so the IAC is not the problem. this is driving me crazy.
Old Aug 1, 2011 | 10:17 PM
rla2005's Avatar
rla2005
I assume that means you tried cleaning the IAC and you still have the issue?
Old Aug 2, 2011 | 02:10 AM
90underconstruction's Avatar
90underconstruction
Have you tried the ignition switch.
When mine went bad, my truck would shut off every time i turned the wheel to the right (even when returning the wheel from a left hand turn) And when ever i tried to change gears (Park to reverse, reverse to drive, ect)
firemarshalmike
31
Jan 19, 2014 09:25 PM
v10hawkeye
Nov 26, 2012 11:20 AM
polkswampkennel
Aug 31, 2011 09:35 PM
jfboy
May 7, 2009 12:04 PM
93Mule
1978 - 1996 Big Bronco
30
Jan 11, 2009 05:01 PM
