460ci HP
Old Jul 2, 2003 | 02:12 AM
ludis's Avatar
ludis
460ci HP
About running high compression engines on today's gas: I've pulled a dozen or more sets of 68-71 heads. The pistons of every 460 (10.5:1) have been fine. The pistons of every 429 (11.0:1 I think) have been damaged. From this small sample, the extra little bit of compression in a 429 seems to be too much for currently available gas.
Old Jul 2, 2003 | 02:28 PM
AG4.0's Avatar
AG4.0
460ci HP
Looks like your Towncar should be getting 202 HP @ 4000 and 356 ft-lb @ 1600. That's if the Towncar is the same as the Mark IV.
Here's a site you might like.
www.automotivemileposts.com/prod1977mark5.html
Old May 6, 2011 | 12:38 PM
codyethridge's Avatar
codyethridge
does any one have pictures of this "smog Bump"????
Originally Posted by georgedavila
You can achieve 360hp using the early or late heads with a compression ratio of about 9.5:1 by piston selection. Grind down the smog bumps on either head, use a cam of about .500/.515 lift, 205/215@.050 duration, a dual plane aftermarket intake manifold, a 750cfm carb, a good set of headers with a true dual exhaust and you'll probably be closer to 400hp.
The weak design in all 385 heads is the exhaust port. It was compromised to fit between strut towers on intermediate sized vehicles of the late '60s and early '70s. Anything you do to enhance the exhaust, such as grinding off the smog bump (worth 25hp according to lore), simple cleaning up of port casting marks and especially a set of headers with a good 2.5" exhaust system is well rewarded.
A good approach is to tear the engine down and put together a working budget for the shortblock. Then you'll know where you're at financially. Everything else is bolt-on, and the shortblock will run fine with stock heads and accessories until additional funds become available for bolt-on modifications.
Does anyone have a picture of this (smog bump)? Im new to these ford 460 motors and i dont have any idea where these bumps are or what they look like.
Old May 6, 2011 | 01:34 PM
KrautBurner's Avatar
KrautBurner
Originally Posted by pyropig
I've got a 1977 town car with a 460, i was wondering if you lincoln gurus that seem to pop in can hook me up with some power ratings
I've got a 77 F250 I too was wondering about HP/TQ numbers for it
I believe the 77 cars had more emissions stuff than the trucks
if I read right, the 77 pickups were the last without catalyst exhaust.
zimman20
Nov 14, 2002 01:24 PM
merc460
Nov 8, 2002 10:09 AM
the law
Sep 6, 2002 01:14 PM
mikej
May 20, 2002 11:08 PM
chilly460
Jul 11, 2000 11:32 PM
