Broken brake rotor on 89 F-350 2WD
Old 11-04-2013, 03:33 PM
NorthwoodGuy's Avatar
NorthwoodGuy
NorthwoodGuy is offline
Ok guys, now keep in mind this is my yard truck and it will be junked in the spring (not looking to break the bank on replacement parts). Noticed the caliper leaking last winter so I just pinched off the line and finished out the season. Getting around to prepping for the coming plow season I got the passenger side pulled apart, and was about to replace the caliper when I found only half a rotor. Wearing surface on one side, worn vanes on the other. How difficult is it to replace a rotor on one of these? Is it as easy as popping a dust cap on the outside, removing a spindle nut, and sliding the hub and rotor off? Unbolt the rotor from the spacer and bolt in the new one? Or do I have to deal with bearings and snap rings and the whole 9? Please tell me this is an easy fix.
Old 11-04-2013, 08:52 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Remove tire
remove locking hub
remove caliper
remove spindle nutS and outer bearing
remove hub/rotor assem
drive out wheel studs
knock rotor off hub
put new rotor on
install wheel studs and drive them in
Install is reverse of removal
Old 11-04-2013, 09:53 PM
fordka's Avatar
fordka
fordka is offline
Originally Posted by Diesel_Brad
Remove tire remove locking hub remove caliper remove spindle nutS and outer bearing remove hub/rotor assem drive out wheel studs knock rotor off hub put new rotor on install wheel studs and drive them in Install is reverse of removal
His is a 2wd. How do you plow with a 2wd the truck must be pretty help less
Old 11-04-2013, 10:59 PM
NorthwoodGuy
Truck actually does pretty well for 2wd. It's got a flat bed with small side rails. With about 500-1000lbs or dirt in it it pushes just about anything. But back on topic if we can. Yes it's 2wd so obviously I don't have to deal with the locking hubs. It's just so odd to me to see rotors that don't just slide off with the calipers off. I should probably just dig in but I really don't want to get into messing with bearings if there's the possibility of them falling out or being damaged by being exposed. (I have no experience with them at all.
Old 11-04-2013, 11:02 PM
slashfan7964's Avatar
slashfan7964
slashfan7964 is offline
Mines a 4X4 and I almost never have to use 4WD to plow unless I'm pushing mountains of that wet s***.
Old 11-05-2013, 12:24 PM
NorthwoodGuy
Again, back on topic if we could. Am I just looking at a spindle nut? I'm not going to be able to dig into it until this weekend but want to purchase the parts I'm going to need and round up the tools ahead of time. Thanks guys.
Old 11-05-2013, 05:22 PM
Diesel_Brad
Sorry. I missed the 2wd prt.
Yes, just remove caliper,dust cap, cotter key, castle nut, washer outer wheel bearing then the rotor will come off. the hub and rotor are one assem on a 2wd
Old 11-05-2013, 06:50 PM
NorthwoodGuy
Will I be able to re-use the bearing? Do I need a special tool to remove it or re-install it?
Old 11-05-2013, 07:09 PM
Diesel_Brad
Reuse bearings. new rotor will have new races. I would change the grease seal
Old 11-05-2013, 08:08 PM
NorthwoodGuy
Anywhere I can find an exploded view of the hub assembly?
Also are the 4wd and 2wd rotors the same? I know the calipers are....
Old 11-05-2013, 08:41 PM
danr1's Avatar
danr1
danr1 is offline
There is very little too a front 2wd spindle/hub so you really don't need one, very simple/basic setup.
Just do it, if you take your time and working with basic hand tools it might take you an hour total to change it.
Couple things you'll wanna know going in (if you don't know them already).
Before putting hub on spindle apply light coat of grease on spindle where the seal rides, clean the area/spindle first.
Be sure and repack the bearings with fresh grease until that new grease appears from between all rollers.
The wheel bearings properly packed need no more grease, in other words don't fill the hub between inner and outer bearings with grease.
Bearing preload, tighten wheelbearing nut to 25 ft-lbs then rotate the hub in forward direction several times to seat bearings, re check/set preload to 25 ft-lbs again if seating changed value, next back off nut 1/8th turn, then finally with your fingers only (no wrench/tool) tighten nut until its snug and install cotter key.
Old 11-06-2013, 04:38 AM
Diesel_Brad
Rotor are NOT the same from 2wd to 4wd
Old 11-11-2013, 07:49 PM
NorthwoodGuy
Thanks for the quick how-to. Install went pretty smooth.
Macdive
1999 to 2016 Super Duty
07-16-2010 05:54 PM
Jim Hunt
06-26-2010 10:43 PM
F-350 Mud Digger
11-28-2009 12:14 PM
xsquid3
10-04-2006 01:46 AM
shenders99
09-08-2006 11:55 PM
Quick Reply: Broken brake rotor on 89 F-350 2WD
