Front Rotor Removal
Old Sep 7, 2006 | 08:18 PM
shenders99's Avatar
shenders99
Front Rotor Removal
I am in the process of changing my hub assembly due to blown bearing and cannot seem to get my rotor off. Does any one have any input for me? I've got the bolts off just fine but the rotor and ?? (wheel carrier bolt up piece won't budge.
...Scott
Old Sep 7, 2006 | 08:42 PM
clux's Avatar
clux
Dumb question:
You do have the caliper assembly off, correct?
Then the the rotor should slide right off the lugs. If it is rusted, you may need to use a soft faced hammer.
jtharvey's Avatar
jtharvey
The rotors can become seized to the hub assembly over time due to corrosion, and that's probably what's happened to you. If you can get the nuts off the back side of the knuckle that's holding the hub in, you can remove the hub and rotor as one piece. Once it's free and easier to work on, you should be able to get some penetrating oil between the hub and rotor. It will probably take some beating to get the rotor off, and you may end up destroying the rotor in the process. Also, if you can apply some heat to the inner part of the face of the rotor, say with a propane or MAP gas torch, it may help it expand some and free it up.
Old Sep 7, 2006 | 08:43 PM
Brian0445's Avatar
Brian0445
is it a 4x4 or 2wd? What part of OH are you from?
Old Sep 7, 2006 | 09:23 PM
shenders99's Avatar
shenders99
4x4 drw medina, OH
Alright, yes the caliper is off, it is a 4x4 drw (which means the extender piece) and I am in Medina, OH.
I have tried with a dead blow with not luck. Also tried a 40" pry bar with no luck. It is no late and did not want to try a sledge and wood.
I guess that I will try to remove the hub from the knuck in the morning and go from there.
It is pretty well rusted on there. Well it is Ohio! Hope this helps you to give me more advice!!
Thanks,,
Scott
Old Sep 7, 2006 | 09:29 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Put the penetrating oil to it tonight. Start again in the AM.
Old Sep 7, 2006 | 10:41 PM
cnd999's Avatar
cnd999
Scott, I was replacing my rotors cause they were junk so I didn`t have any reservations about beating them. If I were saving them I would use a torch judiciously on the seam without transfering too much heat to the hub and bearing. with some penetrant over night and fire like was mentioned and they will come loose.The flame will expand the metal just enough to seperate along with some hammers and blocks, Good luck
Old Sep 8, 2006 | 08:31 PM
shenders99's Avatar
shenders99
Success
So after an hour last night and two this morning I finally got the rotor off the hub.
I removed the hub from the knuckle and the proceeded to beat the heck out of it. No luck. So I took a 2x4 and stuck it into the outer side of the hub were the lock inserts. Well it is a tight fit after I drove it in, but worked great as I beat the crap out of it, 5 minutes later it was apart. Got the studs off in another 15 minutes.
I recommend to get replacement studs (holding the hub to the knuckle) for anyone attemping this, it will save time.
I now have a hub on a stick (2x4).
Thanks for all help...
Scott
Old Sep 8, 2006 | 11:55 PM
jtharvey's Avatar
jtharvey
Well, at least you were replacing the hubs, so the hub on a stick isn't a big deal.
