351W to 460 swap?
351W to 460 swap?
So I have a 1997 F350 with a 351W auto and its a 4x4. The engine has about 150k on it and it need a new oil pan as well as oil pump, and almost every gasket. I also have a 1988 460 with a 5 spd auto and they only have 65k on them. I plan on taking the entire 350 apart to repaint the frame so i was thinking while I'm at it, instead of attempting to redo the cab and floorpans I might as well swap in a 1988 cab that I have to go along with the engine and tranny. In you guys' opinion, what would be the best course of action?
1.) Fix the floor pans, cab dents, and replace 351W oilpan
or
2.) Switch it over to the 460 with matching tranny and cab?
Other questions:
Will i have to change the rear end ratio?
With the T-case bolt up to the 5 spd standard?
Will I have to change my axle ratios (Im 95% sure the truck currently has 3.73 gears)?
Thanks for the help!
or
Other questions:
weldingfreak
04-16-2005 11:27 PM
460swap
06-14-2001 07:05 AM
