What transfer case shifter do I use?
Old Nov 3, 2013 | 08:13 PM
custom1106's Avatar
custom1106
Well...I'm doing a tranny swap in my '94.
Out goes the blown up M5OD and in goes an NP435.
I have everything sorted out, like driveshafts & crossmember stuff, so now I'm trying to figure out what transfer case shifter out of what year would work for the combo I have. The truck has a Borg Warner case. I see a lot of the AOD & E4OD 4x4's in the junkyard, but don't know if those shifters will work or not. The one from the M5OD setup is waaay different, and looks like it won't even bolt up to the NP435. Since the NP435 didn't really come in the 92-96 trucks this may be kind of tough. Would one from a 87-91 setup work?
Any info would be much appeciated!
Old Nov 4, 2013 | 03:45 PM
77 1/2 F250's Avatar
77 1/2 F250
I actually did this swap in my 88 F150. IIRC the NP 435 is shorter than the M5OD; plus as you have realized the it doesn't have mounting holes for the 1356 shifter.
What I did, (and there are many other ways to get the job done) was use the NP 208 that was originally behind the NP 435. The shifter doesn't come up in the same spot, but the transmission cover swapped right over. I did have to block the original hole in the side of the transmission tunnel.
The only part I had to buy was the hydraulic line from the master cylinder to the external slave cylinder, the one on the donor truck leaked.
You may be able to weld up a frame from angle iron that you can mount your shifter on; but it was easier and cheaper for me to swap everything from the bellhousing to the differential yokes.
Robert
olympic1
Sep 22, 2011 08:24 PM
idealtrucks
Aug 13, 2010 10:32 AM
Bear151556
Jan 26, 2006 12:26 PM
HBINGER1
Feb 12, 2003 10:05 PM
