Has anyone ever done a vacuum test with a cigar
Better off taking few minutes put together a smoke machine to check for vac leaks.
Doesn't take much metal container couple fittings little bit of hose and you have it.
vacuumsmoker2_zps3d5cc22e.mp4 Video by danr1 | Photobucket
Made mine with what had laying around the house.
Bonus points for anyone knows what it used to be LOL!
Received 3,090 Likes
on
Reasonable guess based on what can be seen but nope not a receiver/drier.
That video isn't very good at all it was first test run to be sure it'd pump out enough smoke and long enough to be useful, ran video on phone but that was secondary to what I was doing. Wasn't real sure it was big enough vessel keep a smoldering rag going in if at all, rag set on fire with little trans fluid on it then snuffed out, 1 or 2psi of air behind it.
When I actually tested the truck checking it for leaks with the breather blocked off properly set up for the test I didn't record video, I intended to make a better video then but didn't, weather/rain was working against me big time at that point so just got the test done.
Yea I have a handy vac and use it however the smoke machine "machine" kind of a stretch there, I used the term machine becasue that's what they are called. No machine about em though.
I wanted to check for intake leaks didn't think I had one but wanted to check, I found three leaks I wouldn't have found any other way including using plain water as I used to do.
Had two vac lines leaking just a little bit where connected to the vacuum tree, no biggie there couple clamps fixed em quick enough.
Worse leak was the body of the IAC, it leaked out the seam and the vent, I changed out the IAC after seeing it leaking like that. The replacement IAC while it did show a small amount leakage out the vent, normal reaction to "back pressure", it was nothing like the one it had on it and did not leak out the seam at all.
Running in overdrive at 55mph on flat ground/@1400rpm, the vacuum reading increased 4hg after the repair.
It rose from 7hg running at 55mph to 11hg, a decrease in perceived engine loading seen by the computer that should net me an improvement in fuel econ. Might not be much no but take what I can get anyway I can get it @350gal!
Hey danr1 I appreciate the reply man maybe I should just go through and replace all the plastic with new rubber hose but I wouldn't even know what id hose to buy? The reason i asked about the vacuum gauge tester, I just wanted to see how much vacuum I had But I dont know where to check that at, either. Thanks again
Hey man thanks for the reply and I saw the description of your scooter I have an ironhead sporty xlh 1000 its a 82 last of the irons.
Remember the other OBD code 33
I turned the regulator/separator on the compressor down as low as it would go yet still deliver air, wasn't much more than 1psi 2 tops. I could put my thumb over the end of the hose with no effort at all and stop it.
I didn't want to blow every gasket on it in the process but yet enough to show any leaks. The video, video is deceiving far as that goes, makes it look like quite a bit of force behind it but has a weak flow.
