Brake Replacement
Old Jun 21, 2003 | 04:54 PM
HaroldCallahan's Avatar
HaroldCallahan
Brake Replacement
1999 Ranger, 3.0, 5speed, 4x4, 95,000 mostly hiway miles
It looks like the rear shoes are getting close to the rivets. What special tools will I need to do the front disc pads and rear shoes by myself. Any thing to look out for etc. Any particular shoes and pads that I should get ???
Also recently the ABS light went on, and I can tell the antilock is not working. Otherwise the brakes work like new. I am thinking thatt maybe I will just not get the ABS fixed.
If I decide to get the ABS fixed would it best to go to the dealer or is it something I can diagnose and fix myself, if so how. About how much should I expect to pay at the dealer to fix ABS ???
Thanks in advance
Old Jun 21, 2003 | 09:18 PM
Ken00's Avatar
Ken00
Brake Replacement
The fronts are only two bolts once the wheel is off. The rears are a little harder since you have a few springs to remove/install, check out my tech info post at the top of the page and the link on rear brakes. You will need a scanner to pull the code for the ABS problem.
Old Jun 22, 2003 | 04:13 PM
HaroldCallahan
Brake Replacement
Thanks for the reply. I think I will get a scanner and figure this out myself. What kind of scanner do I need to get, where does it plug in, etc.
Old Jun 22, 2003 | 07:07 PM
Ken00's Avatar
Ken00
Brake Replacement
Forgot that some parts stores will do it for free, give that a try, if not then an OBD-II scanner. Plugs in right below the steering column.
1998Ranger25L153CID
Dec 18, 2014 07:33 AM
edsheridan
Aug 25, 2014 02:39 PM
joesmealsonwheels
May 9, 2011 03:57 PM
pdmersft
Feb 29, 2004 06:43 PM
djolly
1997 - 2003 F150
Dec 19, 1999 09:50 AM
