I have a question about when my truck is in 4 wheel drive. I've read a lot of posts but couldn't find specific answers to these questions: When I take a left turn theres quite a bit of resistance and a little hopping. Also when turning in reverse its almost like the truck is getting hung up and a with resistance, something doesn't seem right. Could any of this be if only one hub is engaging? Also, when i just manually lock the hubs, I only noticed that the passenger side axle spins when I manually turn the front drive shaft.
Also this is the first time I've used the 4 wheel drive. And I recently replaced front axle u joints, as well as a double cardan joint rebuild, only issue w/ that is that is i forgot to mark the orientation where the front driveshaft bolts onto the the transfer case...so it's either on the right way or a 180 from how it was before, because I could see the original pattern.
Thanks in advance
-John
yeah they're original. rebuild the ones i got? or get new ones? I would like to get just manual locking and plug the vacuum lines, and i think my hubs are getting pretty worn out.
